Hi all,
Seems like (weather permitting) this will be a great time! Lots of interest. On the "Scottish" part of Gate Trial, I just adopted the title and format from the Texhoma Club in OK. Our plans are to use the Tommi Ahvala rules from the following summary- once again from our friends in Oklahoma. Oh yes, the other reason for the "Scottish" name is the fact that I am a SCOT! (my dad's name was Finis McLean Alexander...)
http://www.geocities.com/clarkp4/ScotTISH_08_flyer.pdfHey Deb, You can score on the uphill rock section.....
Scott, you won't have to wash the bike until spring (that's also part of the new "Scottish" rule book)
Hey Sam- bring the gang! And your warm gloves....
New challange- we need to name this thing... Any ideas????
Does anyone have any extra scorecards they can donate ? We will most likley not use a punchcard- just a simple grid that will allow us to write in the score for each section. The total number of loops will be decided at the event- based on difficulty, weather etc. All sections are close so there will be easy loops back and forth to warmth! The whole property is only 23 acres. I am working on the neighbor to see if we can ride a "killer" rock fenceline (300-400' long) - that will be a longer trail ride out and back if it happens.
Here are the rules:
Tommi Ahvala Gate Trial Rules
The following are what we in Oklahoma call the Ahvala Rules for a gate trial.
Several club gate trials have been run using this scoring method and so far everyone
prefers these rules over the gate trial rules that have been used in the past. For
more information on Two-Time World Champion Tommi Ahvala, go to supertrial.com.
Rules synopsis:
High score wins.
One rider in a section at a time and you receive 30 bonus points when your back
axle clears the entrance gate plane. So, you begin each section with 30 points.
All sections have “gates” of differing point levels, usually a minimum of two gates
at each point level. Higher point gates will be more difficult.
Normally we have 5-point, 10-point, and 15-point gates. Each point level of gate
marker cards are different color; 5-point gates one color, 10-point gates a
different color and so on. We normally mark the gate cards with “5”, “10”, “15”
We typically mark a “gate” similar to a national event with gate cards
approximately 4 feet apart.
Review the section and formulate your own “gate plan” for gaining points over
your competitors. You can ride any gate in any order.
“Cleaning” a gate adds those gate points to your score. A “clean” gate is your
back axle clears the plane of the gate without dabbing.
Once in the section you can ride as many gates as you like but you cannot repeat
a gate and you cannot cross your tracks.
Gates may be marked with direction arrows if the intended direction of travel is
unclear – you cannot ride through a gate backwards unless specifically allowed by
the trials master in selected sections on certain gates. The trials master will
identify whether bi-directional travel is allowed anywhere and on what gates, if
any.
Each dab deducts 10 points from your initial 30 point “ride-in bonus”. Dabbing
never takes away any points you’ve accumulated by cleaning gates – you always
keep those. So the maximum deduction for dabs is 30 points.
If you “five” a gate or a section, you lose your 30 point “ride-in bonus” and you
cannot attempt any more gates in that section but you keep any accumulated
“clean” gate points. Again, you never lose any gate points.
So, you can ride into a section and ride directly to the exit; doing so without
dabbing nets you 30 points for that section.
Footing / pushing your bike through multiple gates to obtain a maximum gate
score violates the spirit of this type of competition. If you attempt a section in
this fashion you will be disqualified from the event and we’ll paint your bike pink
and make you carry a purse during competition in future events.
ADDED RULE 10-30-09
USE OF AUTHENTIC SCOTTISH KILT WILL ENTITLE THAT RIDER TO A FIFTY POINT SIGN UP BONUS.
(other stipulations may apply as set forth by your peers on the day of the event!)
The Older I get - the Better I was.....
