jonboy883
Members
  • Posts
    260
  • Joined
  • Last visited
Everything posted by jonboy883
  1. A great place to practice and ride, if your in any doubt watch some videos of the SSDT or Scott trial on YouTube and you’ll see you have a superb practice area.
  2. jonboy883
    Scorpa 94
    Can you share the video
  3. Sounds a bit like a top end rattle at higher revs, may need small end bearings, easy, quick, cheap fix
  4. Air leak to the crank. Get some silicon sealer, smear to all round the joins on the outside and start it. If there's no revving, there's your issue, new crank seals.
  5. Get him a Scorps Ty125, four stroke. Lovely light, manageable and really easy to ride. Brand new at £4300, you'll struggle to get a good, clean Bantom for the same money!
  6. There is a good Scorpa breakers on eBay, reasonably priced as well.
  7. I'm also going to enter this topic with an entirely different perspective. 2 HR's or 100 miles is not a great distance, most people on here do more miles than that to compete in various trials, so I would suggest contacting the dealer, returning it to them and giving them time to fix it. When they have tested it and even get them to video the test and email to you, then collect it and use it. if they refuse to fix it, get your money back as they know it's not worth the fix up. this way, you either get a fixed bike or you money back, and you'll only be time and petrol money out of pocket.
  8. jonboy883
    Cota 310
    Try carlsalter.com. the Montesa 330 manual is the closest and the engines are virtually identical. At least it will give you workshops diagrams to work from, even if the part numbers are incorrect.
  9. Also, unlike COVID, there is no vaccine, once bitten by the bug, it's a lifelong affliction.
  10. It's type approve to use in the EU, thus the country designation, so, yes it's legal. the not for highway use stuff is for the US market, only ever taken note off, when they are no markings on the tyre.
  11. Credit card on interest free terms!
  12. Hi Mark, I'm up the road in North Dorset. sandpits farm is still there, join XHG Tigers motorcycle club, trials at Stur Marshall and around, and you'll get the info on Sandpits from there. cheers.
  13. If you search for beta rev3 manuals on the interweb, several come up and can be printed. Try this one first, I got a techno one and it's fine:. https://www.carlsalter.com/beta-service-manuals.asp
  14. The clutch as you say in Q1 is exactly that, they free off with use each and every time. Q4 taking a clutch apart is fairly straight forward, give it a go, just place all the bits down on cardboard in the order they came out. sump plug is immediately above the hole drilled in the bash plate,towards the rear of the gearbox, for the purpose, you shouldn't, with the plate on reveal any other plugs.. Filler is on the left side behind barrel if I remember correctly.
  15. Supply some to someone like Trial Tube or BVM Moto for their reviews and get it known out there, Once known, get someone to supply for you.....less profit, easier life however.
  16. Sounds like a master cylinder seal, as the pressure builds the fluid is pushing past an iffy seal internally and going from one side of the piston to the other. Do you need a new master cylinder or just a seal kit?
  17. I had a similar issue on an Aptilia TXR where the rear calliper had been rebuilt and the previous owner had put the Pistons in the wrong way round. Are yours in the right way, if not the large flat surface cannot get the fluid pressure acting on it to move rhe piston out to apply pressure to the pads. Give it a check, at the very least!
  18. Yes of course, the frame and engine numbers normally correspond but the number is there so you can get parts for it which are correct, as well as the obvious security reasons. Contact John Shirt Motorcycles, he should be able to help you with ease.
  19. Quite possibly, I saw in Autumns TRF magazine, they'd registered a Sur Ron electric bike thingy, so a proper looking electric bike should be no issues!
  20. Before that, check all contacts, by unplugging, cleaning and reconnecting first, and a new plug. It's amazing that sometimes the simpler things can cause the biggest issues, but are sometimes overlooked for the bigger issue.
  21. Put some before and after photos on then for us. Good luck with it and welcome back to the fold!
  22. I'm definitely not a KTM fanboy, I had a 200 EXC GS years ago for trail riding, traded it for a CRM, much better. As for Orange Sherco, not me sir, I have a Blue Yamaha, made in France! ?
  23. Well suppose they are essentially a KTM these days.
  24. jonboy883
    Workshop Manual
    Look on the gas gas uk website or John shirt moto suk website!
  25. Take the switch off, keep the wire handy, start bike, touch wire to earth, does it work like the kill switch should. If so, no wiring issues. Once confirmed, fit a decent new switch and it should be good to go.
