Gear Saver Oil?
5 replies to this topic
#1 coldcake
    Member
  • Members
  • PipPip
  • 94 posts
  • Bike:scorpa sy250
  • Club:Dulais Valley
Posted 01 September 2006 - 06:11 PM
hi there,
i'm looking for some advice,been running my sherco 290 '03 on belray gear saver sae 80.just bought new oil from supplier and noticed that it was sae75.it seems a bit thinner.what is best? or is there not much diffrence.also can i buy this by the gallon to make it cheaper in the long run.
happy riding.
#2 gasgas
    Advanced Member
  • Members
  • PipPipPip
  • 270 posts
  • Bike:gasgas 250 pro
Posted 01 September 2006 - 09:31 PM
It is thinner. That is what the sae 75 says.
The thinnier the noisier, but beside that it is both sold as a gear saver, so it won't harm yr gears.
Just poor it in and have a go.
Buy it by the gallon, it is cheaper.
george
#3 copemech
    Advanced Member
  • Site Supporter
  • 8,036 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 02 September 2006 - 03:18 AM
WARNING! DUDE!
These high VI ratings are not always for this application! There are very different VI ratings, basically you need an oil that is designed to work with the CLUTCH, not the gears, and the heavy gear oils will not do that!
Either but the proper oil from your dealer from a motorcycle oil mfg. like IPONE, REPSOL, MAXIMA, etc. or use something like Dextron III or 10-30 motor oil if you are really cheap. Your Honda or Yam shop has something that works if nothing else! Ask them!
Those thick oils will not work well withyour clutch!
For example, the Maxima 75MTF is a different VI scale than 75-90 hypoid gear lube, the latter being twice as thick ov viscosity!
:rolleyes:
I
Ride it Like it was one of your old Girlfriends, If you still remember how!
#4 dale
    Advanced Member
  • Members
  • PipPipPip
  • 167 posts
  • Bike: Sherco 2.9& TY175
Posted 02 September 2006 - 01:24 PM
Hi, been using belray gearsaver in my 05 290 from new,and everybody who has had a go on it says what a lovely smooth clutch it has.I am sure Bel-ray oil was designed for motorcycles in mind. :rolleyes:
#5 coldcake
    Member
  • Members
  • PipPip
  • 94 posts
  • Bike:scorpa sy250
Posted 02 September 2006 - 06:34 PM
yes but which belray sae80 or 75?that's the big question and do you buy it by the litre or gallon?
cheers mister texas but i little to deep for me,i'm just a simple guy with simple mind.bikes,bikes and more bikes.
#6 copemech
    Advanced Member
  • Site Supporter
  • 8,036 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 03 September 2006 - 03:19 AM
Got me qurious so I looked up the BelRay site. Looks as though it should be fine as I was hoping, It IS made for the application!
The thinner the oil, the quicker the clutch action, but the difference should be naught between 75 and 80 i would think.
Cheers,
ps-to confuse you further, Ijust found this on the US Sherco site! Wonder if it applies to Beta, I would think so!
Oil types and levels for the 2006 trials models Paioli front forks
Oil level on right leg: 60mm With forks at bottom Quantity: 370 +/- 4cc Oil level on left leg: 110mm With forks at bottom and without spring Quantity: 385+/- 4 cc Oil type Idemitsu O J RACING TYPE 01 Viscosity at 40º C --> 15.06 mm2 Viscosity at 100ºC --> 3.472 Index of viscosity --> 106
Yea! See if Neonsurge can figure that out! Where are the PENCILS? :rolleyes:
Edited by copemech, 03 September 2006 - 03:38 AM.
