200 4 Stroking
6 replies to this topic
#1 superhondaman
    Advanced Member
  • Members
  • PipPipPip
  • 257 posts
  • Bike:Fantic 200, Cub
  • Club:ESTC/Leamington Victory
Posted 22 October 2006 - 10:26 PM
Had a problem with my 200 a while back it seemed like it had killed a plug,then it got worse would run ok 2/3rd's of the trial then start to feel as though its 4 stroking?, i replaced the main coil, ok again for a couple of trials, then it started again, plug colour is fine, had the small coil behind the flywheel rewound, and its still 4 stroking, could the timeing be out? when i replaced the coil the lines were 'in line' on the flywheel. Any help appreciated!
#2 feetupfun
    Advanced Member
  • Members
  • PipPipPip
  • 1,377 posts
  • Bike:1963 to 1981
Posted 23 October 2006 - 11:08 AM
Why are you so sure it is an electrical problem? If it is 4 stroking, it may be the fuel/air mixture is too rich. There are many things that can go wrong to cause an intermittent rich mixture.
Helping to diagnose the problem needs more info.
Under what riding conditions does the 4 stroking happen ie throttle position, bike attitude, engine warm or cold, RPM sensitive, during accelleration or constant speed, anything coming out the float bowl overflow, does it go better after you turn the fuel tap off?
You put my Basil in the ratatouille?
#3 superhondaman
    Advanced Member
  • Members
  • PipPipPip
  • 257 posts
Posted 24 October 2006 - 08:30 PM
Ok just been in the garage,checked carb cleaned it out all fine new plug in. On starting at cold running badly when you try to open the throttle its missing but i noticed that after a second the blue exhaust smoke changed to black, as the revs went lower it would return to normal colour.checked the plug and it is now black and oily. It is missing, 4 stroking, running rough cold or hot.
Thanks for your help.
#4 Lee Harris
    Advanced Member
  • Members
  • PipPipPip
  • 1,104 posts
  • Bike:Fantics
Posted 26 October 2006 - 10:26 AM
I would drain the gearbox oil to check to see if its all there. i had a minarelli crank seal go on mine last year and that woz difficult to diagnose but easy to cure!
lee
I swear to drunk I'm not God!"
#5 axulsuv
    Advanced Member
  • Members
  • PipPipPip
  • 1,396 posts
  • Bike: 240 pro fm330 ty80
  • Club:ITSA , STRA , MTR, AMA
Posted 26 October 2006 - 10:28 AM
Crank Seals leaking ? (trying to burn gear oil !?)
Glenn
Lee we were typing at the same time ! Brilliant minds must think alike !...
Glenn
Just a old trials kid !!! ITSA , STRA , MTR
And you never see a motorcycle parked in front of a psychologists office ...
"Traction is where you find it "
"To acheive anything in this game you must be prepared to dabble in the boundry of disaster" (Stirling Moss)
#6 superhondaman
    Advanced Member
  • Members
  • PipPipPip
  • 257 posts
Posted 23 December 2006 - 06:48 PM
On checking the timing i noticed that the pick up from the flywheel which is held onto the stator plate was loose. After tightening the 2 screws the bike runs fine! anyone else had this problem.
#7 axulsuv
    Advanced Member
  • Members
  • PipPipPip
  • 1,396 posts
Posted 24 December 2006 - 02:24 AM
:beer: That works for me ! I've never had mine come loose , but that could definitely change the timing enough , Or cause the spark to be intermittent , to do what you described as the running condition of the bike ! Would it randomly be a witch to start to ? possible starter lever kickbacks ????
Sorry for the worst case Internet diag....................
Keep the FANTICS alive !!!! :thumbup:
Glenn
