Rear Shock Leaking
17 replies to this topic
#1 hugo
    Member
  • Members
  • PipPip
  • 60 posts
  • Bike:Sherco ST2.9 2012
  • Club:A.T.A.Q. Québec, Canada
Posted 01 June 2007 - 04:00 PM
Hello Sherco riders,
The rear shock started to leak on my 2006 Sherco 2.9. In owning 3 other trial bikes previously, (and some of them much older than this one), I never faced this problem.
The shaft has no dent or mark whatsoever. It gets wet from oil just by hopping the bike. I clean it, hop on the bike and you see it gets messy again. Not a major leak, but there should be none at all.
I guess it’s a matter of replacing a defective seal, but I know it’s not something you can do without the proper tools and expertise…
- Do you think any suspension shop would be able to work on it or I need to find someone that works specifically on that brand (Olle), in which case it might be difficult to find one locally.
- If the price is OK, upgrading for the 07 (adjustable shock) would be another option… would someone happen to know if the 07 shock will fit the 06 frame ? I know they changed the swingarm in 07 so I’m not sure of the compatibility.
Thanks.
Hugo
Edited by hugo, 28 June 2007 - 02:58 AM.
#2 Essex Rider
    Advanced Member
  • Members
  • PipPipPip
  • 666 posts
  • Bike:SHERCO 320 4t
  • Club:Castle Colchester
Posted 01 June 2007 - 07:21 PM
Thanks.
Hugo
i too would be interested to know about the seal replacement as mine has been doing this for a while, although i cant feel the back end becoming any different.
As for the 07 shock...it will fit although i think they are rather expensive
Edited by Essex Rider, 01 June 2007 - 07:23 PM.
TRIALS RIDERS DO IT FOR SIX DAYS!
SHERCO RULE AND BETAS DROOL!!
#3 gtgasgas
    Advanced Member
  • Members
  • PipPipPip
  • 177 posts
  • Bike:04' RAGA #224
Posted 01 June 2007 - 09:54 PM
You have 2 ways to go with this 1 is buy new and the other is have it rebuild and have a good chance of it doing it again. I have rebuilt several and they were good for a year or two. Contact your local Sherco rep. and see if they can help.
Edited by gtgasgas, 01 June 2007 - 09:55 PM.
#4 motofire
    Advanced Member
  • Members
  • PipPipPip
  • 329 posts
  • Bike:2006 Sherco 2.9
Posted 01 June 2007 - 10:01 PM
Hi Hugo...hows things?
This may be of no use to you but......
I too had the same symptoms with my shock(same bike). I would clean it and go for a quick ride and again I would have oil residue there. I took the shock off cleaned and inspected it throughly. Later...I found I was wasting my time because I finally realized that my crankcase breather hose was venting right onto my shock. This is probably not your case but I really wished I had someone suggest to me to check that breather hose before I tore into the shock.
Edited by motofire, 01 June 2007 - 10:02 PM.
#5 copemech
    Advanced Member
  • Site Supporter
  • 8,049 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 01 June 2007 - 11:40 PM
Hugo,
Not sure where you are located, but I have not found anyone to rebuild the Olle or Sachs shocke here.
The TRP shock from Jitsie look like a good alternative and is adjustable.
Lewisport USA is advertising shock work and Ohlins now, so an e-mail to Adrian might be in order.
Ride it Like it was one of your old Girlfriends, If you still remember how!
#6 hugo
    Member
  • Members
  • PipPip
  • 60 posts
Posted 05 June 2007 - 01:29 PM
Thanks for the hints…
Maybe I was too quick to call it a leaking shock…
As per motofire’s comment about the breather hose, I decided to check for any outside source of fluid…
After removing the shock unit from the bike and even removing the spring, I noticed that some fluid was actually retained in the center of the bumper/cushion (that yellow mushy pad fitted on top of the shock’s shaft), so the actual fluid I was referring to was maybe not coming from the seal/shock itself (?) Not sure yet how fluid could be spilled over in that area (the breather hose is not in the way). Anyway, I’ve cleaned everything, bounced the bike a few times and it stays clean so far. Will give the bike a real ride soon and check again.
#7 hugo
    Member
  • Members
  • PipPip
  • 60 posts
Posted 28 June 2007 - 02:50 AM
Ollé! Ollé! It is definitively leaking...
It even starts to squeak when used intensively.
It is still doing its job but I guess it's just a matter of time until the only thing acting as a suspension will be that big yellow spring.
So really, nobody knows about some place that have experience in rebuilding Ollé shocks ?
I can't even find the website of that Ollé company, no wonder why no one knows about them...
Posted Image
Edited by hugo, 28 June 2007 - 03:01 AM.
#8 copemech
    Advanced Member
  • Site Supporter
  • 8,049 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 28 June 2007 - 03:56 AM
Looks as though there may be a nick out of the seal, but leaking still.
Not sure where you are located, but a couple of the UK guys reported that the distributor replaced the shock with the '07 version for a minimal fee. Otherwise, I would seek out the adjustable TRP, or the Ohlins dependant upon cost. The rebound adjustment lets you quicken them up a bit.
The squeak noise usually means u need to spray some lube on the lower bushing jount. If it starts making a squishing sound when you push on the mudguard, the oil in the shock is getting low, but yours may not be there yet! <_<
#9 johnnysherco
    New Member
  • Members
  • Pip
  • 22 posts
  • Bike:08 sherco 320 4T
  • Club:OMCC
Posted 05 July 2007 - 12:22 PM
Hello All Sherco riders
It may not be of help to all but down here in Victoria Australia we have a suspension specialist who can and does all my repairs on the Sachs 05, Olle 06 and Olle 07 Sherco shocks.
He has also rebuilt Beta shocks for me.
The success rate of the repairs has been 100% no problems at all with some of the repairs being better than new.
We are at the moment developing a new rear shock which will give us 22 compression settings and 60 rebound settings with a remote gas reservoir all fitted to a Sherco with minimal fuss.
This shock is fully rebuildable and can be revalved to suit any requirments.
Sherco Victoria Australia
e-mail
sherco@jjmarinecraft.com.au
#10 Peter_GasGas
    Member
  • Members
  • PipPip
  • 74 posts
  • Bike:Sherco 2.9 06
Posted 11 December 2007 - 06:44 PM
Hi guys.
I've also had that problem with my 06 sherco. been running it like this for a while now but i think i'll treat myself for xmas and get a new shock....
My question is: will an ohlins shock (off a GGpro) fit my sherco?
Many thanks in advance.
Peter
#11 Nigel Dabster
    Advanced Member
  • Members
  • PipPipPip
  • 6,560 posts
  • Bike:Gas Gas Bultaco 340
  • Club:Milton Buzzard MCC,Richmond MC
Posted 11 December 2007 - 08:01 PM
View PostPeter_GasGas, on Dec 11 2007, 06:44 PM, said:
Hi guys.
Peter
There are some ohlins here in the uk specifically for shercos.
#12 Peter_GasGas
    Member
  • Members
  • PipPip
  • 74 posts
Posted 11 December 2007 - 11:39 PM
I have a friend thats selling an ohlins rear shock that he used for a while on his pro... will this fit my sherco?
thanks :closedeyes:
#13 sherpa
    Advanced Member
  • Members
  • PipPipPip
  • 105 posts
  • Bike:sherco
Posted 12 December 2007 - 01:25 AM
Don't know if he still does it, but Bob at BJ racing used to rebuild the sherco shocks, he could also mod the non adjustable shock to adjustable for a modest cost as compared to new.
try bob at: www.bjracing.com you may want to get his phone number off the site and call him as he is not to reliable with answering email inquiries.
#14 hugo
    Member
  • Members
  • PipPip
  • 60 posts
Posted 16 December 2007 - 09:48 PM
thanks :thumbup:
No, the one straight from the GG won't fit the Sherco. (Maybe you can have it modified. Not sure of what would be involved exactly...)
By the way I finally had mine (my Ollé) repaired by a suspension shop here in Canada (Stadium Suspensions).
#15 EastCoastHopper
    Member
  • Members
  • PipPip
  • 41 posts
  • Bike:2006 Sherco
  • Club:Rock and Roll Trials Club
Posted 06 January 2008 - 08:55 PM
My shock is leaking also. 2006- 2.9. Ryan Young says they aren't rebuildable.
Seems like it should last for more than one season of riding!
:D
AD ASTRA PER ASPERA
Keep your feet off the ground and keep reaching for the stars!
Facebook: EastCoastHoppers
