Trials Central: Carb Manifold / Extension - Trials Central
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Carb Manifold / Extension Where can I buy one? Rate Topic: -----
#1 User is offline   Beamish Owners Club
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:RL325 outfit plus
  • Club:Worthing, Normandy and Horsham & District
Posted 08 September 2007 - 08:08 PM
I have a C15, a B40 and a Tiger Cub that all need to have the carb moved further from the engine to help stop fuel evaporation (or something like that!). Does anyone have any idea where to buy such an animal?
Cheers,
Jim
#2 User is offline   odgie
  • Member
  • PipPip
  • Group: Members
  • Bike:BSA/Sunbeam
Posted 09 September 2007 - 07:47 AM
Sorry I can't help with where to buy one, I usually make my own, but it is a very good mod to do. Not only will it help keep the fuel cool and hence improve carburation generally, a longer inlet tract also helps increase bottom end torque - it's one of those win/win situations really :-). So well worth persevering with. Hopefully someone on here will have better info for you. Good luck.
#3 User is offline   PeterB
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:OSSA TR280i
  • Club:Waitemata
Posted 11 September 2007 - 10:06 PM
You can easily make one up to suit using 6 x 30mm mild steel flat bar, cut out the flat bar to match the cylinder head inlet tract and another piece to match your carb, then join these two together in the correct plane with a piece of tube approx 25mm dia using brazing. This minimises the distortion. To further help with reducing distortion, clamp the flat bar solidly to a solid piece of steel while brazing. This worked well for me.
Bye, PeterB.
#4 User is offline   Alan_nc
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:BSA, Sherpa T, TY250
  • Club:CVOTC, AMA, AHRMA
Posted 19 September 2007 - 03:02 PM
Standard Norton or Triumph carb extension fits. I'm using one on my 59 D7 Bantam in competition now. It's a direct bolt-up. I have pictures if you would like. Moves the carb back about 2", seems to have solved my heating problems. I also have a "thermite" (or whatever that stuff is) spacer/gasket on both sides of the extension.
Alan
#5 User is offline   mcman56
  • Advanced Member
  • Group: Site Supporter
  • Bike:Rev3, Reflex
  • Club:PITS
Posted 28 May 2010 - 03:13 PM
What would be a good length spacer for a C15? For the machined ones, are they aluminium?
#6 User is offline   Old trials fanatic
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:James Bulto TY Ossa
  • Club:Peak Classic, Dales Classic, AA, Tufty.
Posted 28 May 2010 - 06:45 PM
FWIW when i had my old B40 i just turned two stubs up on the lathe c/w flanges and used a Bultaco inlet manifold rubber. Gave me the right length provided, heat insulation and isolated any vibration probloems reducing frothing in the carb.
Simples :rolleyes:
Then again if you havent got access to a lathe :o
The Victor Meldrew of Trials Central. Wow i'm now even less popular than Omar Gadaffi.
#7 User is offline   mcman56
  • Advanced Member
  • Bike:Rev3, Reflex
  • Club:PITS
Posted 28 May 2010 - 08:40 PM
That is a good idea. I have a lathe. Do you have any pictures?
#8 User is offline   charlie prescott
  • Advanced Member
  • Bike:bsa Otter's Etc,
Posted 29 May 2010 - 08:29 AM
Hi Guys
Check out the BSA "Otter" site, Pictures of OTF'S old bike and carb extentions.
Regards Charlie. http://www.bsaotter.com/
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
