125 Pro Fan Not Cutting In
3 replies to this topic
#1 agiow
    Member
  • Members
  • PipPip
  • 59 posts
  • Bike:beta rev-3 250
Posted 07 February 2008 - 09:16 PM
125 Pro Fan Not cutting in
Run out of ideas 07 125 Pro fan won’t cut in
I’ve applied 12v straight to the fan and spins like new
Checked all wiring and earths, just fitted a new thermostat
Still won’t cut in , even replaced the black box that feeds power
to the fan with known working box , but to know avail fan still
refuse’s to cut in.
Anybody got any ideas ?
#2 no1
    Advanced Member
  • Members
  • PipPipPip
  • 112 posts
  • Bike:jst gasgas
Posted 07 February 2008 - 11:06 PM
What black box did you replace was it the one on the fan cowl (rectifier) it wont be that one it is the one under the bottom yolk on the frame (regulator) the fan has a constant live to it all the time the thermo sender gives an earth
#3 tombo46
    Advanced Member
  • Members
  • PipPipPip
  • 534 posts
  • Bike:2008 Gas Gas 300
I recently had a problem with my regulator and had to replace it. replaced the thermostat too, when the wires were crossed the fan ran fine but it wouldnt start up.
in the end i went down the garden and gave the motor some hammer until either the fan kicked it or the coolant boiled over.
Luckily the fan kicked in but it had to get bloody hot!!
does it work if you just bypass the thermostat?
Tom
If toast always lands butter side down, And cats always land on their feet, What would happen if you buttered a cats back?
#4 agiow
    Member
  • Members
  • PipPip
  • 59 posts
Posted 07 February 2008 - 11:43 PM
"What black box did you replace was it the one on the fan cowl (rectifier) it wont be that one it is the one under the bottom yolk on the frame (regulator) the fan has a constant live to it all the time the thermo sender gives an earth "
Much appreciated no1 didn’t realize the fan had a permanent live feed
from rectifier. I’ll try replacing regulator.
