New Rear Wheel
4 replies to this topic
#1 kevhenson
    Member
  • Members
  • PipPip
  • 45 posts
  • Bike:2010 Evo 300
  • Club:earl shilton trials club
Posted 10 February 2008 - 04:41 PM
my lads 05 125 has "lost" 3 of the bolts out the rear sprocket and 4th one was loose which has elongated the holes that hold the sprocket to the hub, does anyone know of a fix or how much am i lokking at for a new wheel?
cheers
#2 dabomb
    Advanced Member
  • Members
  • PipPipPip
  • 150 posts
  • Bike:sherco
Posted 10 February 2008 - 07:56 PM
The best way is to use helicoils.You drill the hole out to a given size,tap the hole,then screw a special wire insert into it,which contains the original thread size.Its a simple job if you are handy.Go to an engineers merchants,explain to them what you have done,they should be able to help.Not sure how much a kit would cost,but it wouldnt be that expensive.
Failing that,you could drill the holes out in the hub and tap them the next size up,but every time you put a new sprocket on you would have to drill the holes out(in the sprocket)to fit the larger bolts.
Wembley...i was there!!!!
#3 kevhenson
    Member
  • Members
  • PipPip
  • 45 posts
  • Bike:2010 Evo 300
Posted 10 February 2008 - 08:38 PM
on the gasgas the hub isnt threaded its a nut and bolt job, unfortunatly its elongated what was m8 to nearly a 12mm slot... i did think about drilling out until i seen how much by
#4 G14GAV
    Advanced Member
  • Members
  • PipPipPip
  • 114 posts
  • Bike:GasGas
  • Club:Richmond MCC
Posted 11 February 2008 - 06:28 PM
Weld the hole up and re drill it! bout 5 min with a tig!
"God Loves A Trier"
*Online Marketing Specialist*
#5 kevhenson
    Member
  • Members
  • PipPip
  • 45 posts
  • Bike:2010 Evo 300
Posted 11 February 2008 - 08:30 PM
now i like that idea just need someone near me now who can weld
thanks
tried the local metalworkers and they wont weld it cos the wall section is to thin for the depth of weld... worth a try tho
Edited by kevhenson, 12 February 2008 - 08:14 PM.
