Neo,?
Started by copemech, Feb 12 2008 03:29 AM
4 replies to this topic
#1
Posted 12 February 2008 - 03:29 AM
Did you get your shock apart? Just qurious, still not sure if it is the same as the '07, has anyone taken the spring off the newer ones?
Ride it Like it was one of your old Girlfriends, If you still remember how!
#2
Posted 13 February 2008 - 06:26 AM
Hi copemech,
Yep, on my 06 Shock. I got the spring out with ease, once I'd dropped the spring down and removed the wire/clip thing.
I've not touched an 07 Shock, so I can't comment. But it would be easy to check, once you've dropped the spring.
Best of balance.
Neo
Best of balance.
Neo
My Bike ....www.trialscentral.com/forums/garage/vehicle/516-sherco-250-2t-racing-red/
TRIALS....It's not life or death....It's much more serious than that!!
#3
Posted 01 August 2008 - 10:45 AM
Hi copemech,
I think it was you that put up a post some time back about fitting an 07 hock to your Sherco and were not clear which way up/around it should go?
Anyway. I bought an Cabestani Rear shock off of eBay a couple of weeks ago. But I can't see how I can fit it and make the rebund adjusting screw easily accessible on my 06 250.
At the moment I've got it fitted at the top. towards the exhaust box. Which really means I'd have to remove the exhaust box (or Air Box) to get to the screw.
Am I missing something??...or was this an odd way to design a shock?
Best of balance.
Neo
Best of balance.
Neo
#4
Posted 01 August 2008 - 08:47 PM
Hi Neo, With the rebound screw at the left/ lower/back you will be able to get at it without taking anyting off. It's a little tricky but achievable. Hope this helps as I had your worries initially.
#5
Posted 09 August 2008 - 11:02 AM
Neo, on Feb 13 2008, 04:26 PM, said:
Hi copemech,
I can now confirm that it is the same as the 06 Shock.
Best of balance.
Neo
