Can't Remove The Cylinder (2002 315r)
9 replies to this topic
#1 elctb
    Member
  • Members
  • PipPip
  • 36 posts
  • Bike:2010 Beta EVO 250
Posted 03 June 2008 - 04:25 AM
I can't remove the cylinder off my 315r no matter how hard I try. The cylinder head came off without any problem, but the cylinder doesn't budge. I've hit it with a rubber mallet from every possible angle and it hardly moves. I removed the 4 nuts that hold it down. Is there a trick to removing the cylinder or should I keep hitting it with the mallet ?
#2 NZRalphy
    Advanced Member
  • Members
  • PipPipPip
  • 605 posts
  • Bike:Beta Rev4T
Posted 03 June 2008 - 05:38 AM
Humm
You are sure all the bolts are undone???
Try a bit of WD40 on the base gasget overnight to see if it could get it to let go.
or you could try putting a filter strap wrench around the cylinder and giving it a tweak in both directions.
or the base gasket may go soft with a bit of heat.
or put the cylider head back on and Kick it over (quitely)
Very very very very last option.... tap a small wedge between the two.... go through the base gasket in a few places (but i didn't tell you this. And i'd work for a week on the cylinder before trying this).
Ralphy
I'm not half as good as I think I though I was...
#3 feetupfun
    Advanced Member
  • Members
  • PipPipPip
  • 1,379 posts
  • Bike:1963 to 1981
Posted 03 June 2008 - 09:51 AM
Put soft plasticene (oil based modelling clay) in a layer about 6mm thick on top of the piston and refit the head. Carefully bump the cylinder loose by turning the crankshaft.
When the gasket joint lets go, take the cylinder head back off and lift the cylinder off the rest of the way by hand.
You put my Basil in the ratatouille?
#4 tt5th
    Advanced Member
  • Members
  • PipPipPip
  • 386 posts
  • Bike:315, TY Mono
  • Club:RMC, DMC
Posted 03 June 2008 - 11:11 AM
Mine was a swine to do as well. It took a lot of rubber mallet action to get it freed up.
Once I had got a crack to appear between the cylinder and crankcase I put a screwdriver in, not as a wedge but as a lever and then malleted the opposite side.
Not sure how clever an idea this was but it worked. I had one corner that was particularly stuck.
I like the plasticine idea!
#5 fastducs
    Member
  • Members
  • PipPip
  • 98 posts
  • Bike:many
  • Club:NETA
Posted 03 June 2008 - 05:19 PM
How about nylon rope instead of plasticine? Move the piston down into the bore, then cut a few feet of nylon rope and coil it inside the bore on top of the piston. Reinstall head, then kick gently as suggested by feetupfun
I like people who live on the edge ... they leave more space for me.
#6 elctb
    Member
  • Members
  • PipPip
  • 36 posts
Posted 04 June 2008 - 01:45 AM
Yes, that's exactly what I did. It took several kicks but it finally came off.
#7 elctb
    Member
  • Members
  • PipPip
  • 36 posts
Posted 14 June 2008 - 02:19 AM
Is there a trick to install the engine mounting bolts ?
After replacing the piston, rings, and installing the cylinder the engine mounting points are not aligned. I can't even bolt on the frame down tubes. It seems to me the only way to do it is to use some sort of a press. I really think it's humanly impossible to force the mounting points to align.
I hate taking the bike to the shop to get that done.
Any ideas on how to do it ?
Edited by elctb, 14 June 2008 - 02:22 AM.
#8 elctb
    Member
  • Members
  • PipPip
  • 36 posts
Posted 14 June 2008 - 05:36 AM
Well... after strategically loosening a bolt here and there I was able to make it work. All is good now.
#9 elctb
    Member
  • Members
  • PipPip
  • 36 posts
Posted 15 June 2008 - 07:46 PM
One more things. Does anyone know the torque specifications for the cylinder bolts and head bolts ? I can't find anywhere how tight they should be. I'm using 10 lbs/in for now.
#10 tt5th
    Advanced Member
  • Members
  • PipPipPip
  • 386 posts
  • Bike:315, TY Mono
  • Club:RMC, DMC
Posted 15 June 2008 - 10:17 PM
It's 8Nm for both.
