Sign in to follow this
Followers 0
scraggydog64
Rev 3 Reluctant To Change Gear
5 posts in this topic
Hello
I have an 06 Rev 3 250. The gear selection is terrible and finding neutral is very hard. I goes through the gears perfectly without the engine running. The clutch works fine in terms of controling the drive. I use Dextron 3 AFT in the gear box.
I am assuming it is the clutch. I stripped it down and there are no groves in the basket. I cleaned the steel plates with emery cloth to remove any glaze as this used to work on my old 315 Mont. I eventually replaced the friction plates on the Mont - problem solved.
Has anyone had a similar problem with their Beta? If so what did you do? If it is the clutch any advice on where to get one and how much it cost?
Thanks in advance.
Scraggydog.
Share this post
Link to post
my bike and all other previous bikes (sherco and a gasgas) were very difficult to change into nuteral when the engine is running. they are like this to prevent the gear selector selecting nuteral if it hits a rock. and on my bike the change between 1st and 2nd is a little sticky, i recon this is for the same reason
Share this post
Link to post
Yep, me too. I think that this is normal.
Share this post
Link to post
when did you last change the gear oil? it's time to change the oil if your having problems changing gear
Share this post
Link to post
I have an 06 beta , I go into 1st ,up to 2nd then gently knock down into netural, seems to work fine, 2nd to 3rd ,I sometimes get 2 clicks and i am unsure if I have gone into 4th , they way the selectors work I dont think I can go 2 gears in one lift is that true??
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
