08 Sherco 290 Forks?
9 replies to this topic
#1 dazza24
    New Member
  • Members
  • Pip
  • 4 posts
  • Bike:Sherco 290 '08
  • Club:Lincoln cc+mc
Posted 18 July 2008 - 08:11 AM
I have an '08 290 and wondered if anyone else thinks the fork action is soft on the first part (spring) and then goes rock hard after, like it's hitting the air gap. Didn't know if this is how they're supposed to be cos they only have one spring and need the air gap small. My dealer tells me the gaps should be 180mm in the damper side and 60mm in the spring side, while the manual says 150mm both sides. I rode an older model which had full stroke in the forks and it was much better. Ideas anyone?
#2 HAM2
    Advanced Member
  • Members
  • PipPipPip
  • 2,707 posts
  • Bike:Sherco 290-05
  • Club:Jurreh Sinclurs.... Pheonix
Posted 18 July 2008 - 09:31 AM
This is my best guess, but it sounds like you have too much oil in there somewhere.
You've just described how my forks feel when I overdo the fluid!
For the last time...it's not 'SUPPOSED' to have a seat.
There are two types of men in this world:-
1) Those who are Geordies and..
2) Those that want to be.
#3 johnkennedy
    Member
  • Members
  • PipPip
  • 86 posts
  • Bike:2008 beta 250
  • Club:lochabermcc.com
Posted 18 July 2008 - 12:51 PM
i would go with the manual, the dealer seems to be talking bout the pioli forks, which are on the 2007 modle. the new range have centuri (or something sounding that) forks, they will no doubt work diffrently and will require diffrent levels of fork oil the the previous years.
if it doesnt work you could always go back to what they were before.
A Good trialist learns from his own mistakes,
A Great trialist learns from others.
#4 clav3
    Member
  • Members
  • PipPip
  • 60 posts
  • Bike:2008 Sherco 290
Posted 18 July 2008 - 01:06 PM
Below is an email from Ryan Young. I've changed my fork oil on an 08 and it's perfect. Just make sure you get all the oil out of the cartrige side to get all the fresh oil in, and it didn't take 20 minutes, at most 5.
There is a pdf file on Ryans' Sherco site containing this info,
along with the other service files.
The Ceriani forks are identical to the old Paioli except for the outer fork legs.
Oil level on right leg: 60mm
With forks at bottom
Oil level on left leg: 110mm
With forks at bottom and without spring
Should be 370cc in right and 385cc in left.when doing this use the oil height
measurements taken from the top of the forks with the forks at the bottom of there stroke and with the spring removed.
The oil quantities are correct. The levels are correct. The problem is getting all the oil out of the
fork on the cartridge side. You have to pump it for 20 minutes. Then when
you put oil back in, pump for 20 minutes again, to get all the air out of
the cartridge to verify level.
Edited by clav3, 18 July 2008 - 01:16 PM.
#5 shercoman2k8
    Advanced Member
  • Members
  • PipPipPip
  • 601 posts
  • Bike:09 Paxau Sherco 125
  • Club:L&DMCC
Posted 18 July 2008 - 02:59 PM
View Postjohnkennedy, on Jul 18 2008, 01:51 PM, said:
i would go with the manual, the dealer seems to be talking bout the pioli forks, You Mean Paioli?
which are on the 2007 model. the new range have centuri (or something sounding that) forks,You mean Ceriani? they are Paioli!!
they will no doubt work differently and will require different levels of fork oil the the previous years.
if it doesn't work you could always go back to what they were before.
#6 johnkennedy
    Member
  • Members
  • PipPip
  • 86 posts
Posted 18 July 2008 - 09:27 PM
they were spelt phoneticaly.
#7 shercoman2k8
    Advanced Member
  • Members
  • PipPipPip
  • 601 posts
  • Club:L&DMCC
Posted 18 July 2008 - 11:45 PM
Ha! Ok, what ever you say :thumbup:
anyway, should be roughly the same as there both paioli
#8 johnkennedy
    Member
  • Members
  • PipPip
  • 86 posts
Posted 19 July 2008 - 09:45 AM
if so, which they are. why would sherco advertise thier bike with "new Ceriani front fork" if they are exactly the same as the 2007(plus previous modles).??????? i suppose that they must be new because the have a fancy "new" kevlar sticker. :thumbup:
#9 shercoman2k8
    Advanced Member
  • Members
  • PipPipPip
  • 601 posts
  • Club:L&DMCC
Posted 19 July 2008 - 06:42 PM
View Postjohnkennedy, on Jul 19 2008, 10:45 AM, said:
I suppose that they must be new because the have a fancy "new" kevlar sticker. :thumbup:
Looks smarter,
Edit: Found out the ones that say ceriani are fully adjustable for rebound AND dampening
Edited by shercoman2k8, 19 July 2008 - 06:51 PM.
#10 dazza24
    New Member
  • Members
  • Pip
  • 4 posts
Posted 25 July 2008 - 08:03 AM
Well after a bit of experimentation, i've ended up at 140mm air gap in both forks, with spring. Loads better on everything, for me anyway.
