Lost The Spark On An '02 Sherco 290
12 replies to this topic
#1 mark1161
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:Montesa 4RT
Posted 21 July 2008 - 07:58 AM
We were out playing in our local practice ground yesterday and my pals' '02 290 lost it's spark and died (his highly technical description was it went "Papapapapa...papapa.......papa.............pa ............poot!!") - we tried the usual things that you can at the side of river (check it's getting fuel, check he kill switch, tried a new plug) but nothing, so he pushed it the mile and a bit home .........
Having looked at other posts, I'm suspicious that it's the stator - anyone got any experience of this sort of thing and should I be checking anything else ?
Edited by mark1161, 21 July 2008 - 07:59 AM.
#2 copemech
    Advanced Member
  • Site Supporter
  • 8,053 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 21 July 2008 - 06:31 PM
Checking the flywheel key, the box/coil and the stator are the highpoints!
Heres a discussion on the stator on pg 3stator specs
Ride it Like it was one of your old Girlfriends, If you still remember how!
#3 dickv8
    New Member
  • Members
  • Pip
  • 6 posts
  • Bike:sherco 290
Posted 21 July 2008 - 08:16 PM
hello i had the same problem at this years tt my 05 290 was the same i found out when i stripped it that the woodruff key that lines the flywheel up had snapped it cost £2 to rectifie thats if it has not damaged the magnito hope this helps
#4 mark1161
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:Montesa 4RT
Posted 22 July 2008 - 07:03 AM
I pulled the bike apart last night and unfortunately the woodruff key is fine.......
I checked all the connections in the loom and they're all OK as well
The kill switch is working fine
Has anyone got any info on how to test the box/coil ????
I took the thermo-switch out of circuit by connecting its feed wires together and when I kicked the bike over it was generating enough power to start the fan turning so i think the coils on the stator are OK..... somebody please correct me if this is a wrong assumption
I measured the trigger figures as per the instructions from the Bradford ignitions website and got some really oddball figures, so I think that may be the problem - watch this space......
#5 kjax
    Advanced Member
  • Members
  • PipPipPip
  • 145 posts
  • Bike: Sherco 2.9
  • Club:East Side-MOTA - Bent Wheels CC (MI Dist 14)
Posted 05 August 2008 - 12:39 PM
I may be a bit late, just ran across this thread today. I had the same problem (twice in 2006) with my 04 2.9. I was going to try a new stator as well. Turned out it was a grounding issue under the tank with the coil and other electrics. A quick clean and remount solved the problem first time. Then it re-occurred. Next time I did every connnestion and mounting carefully and used di-electric lube in the reassambly. It worked and has been fine for almost 2 years now. Total cost $5.00. Just a little time.
The Older I get - the Better I was.....
#6 mark1161
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:Montesa 4RT
Posted 09 August 2008 - 05:01 PM
An update (but not a happy ending with a big, fat blue spark) - got the stator back from being re-wound (we were convinced this was the problem), built the bike back up, connected all the electrics and hey presto.....no spark !!!!!!!!!
Has anyone any ideas what else it might be, I've checked all the wiring, the kill switch, a new plug and had the stator re-built - I will check the earth connections out tomorrow..........the only thing left is the coil / CDI unit and I expect it will be f*@&ing expensive - does anyone know how to test one (and unfortunately none of ou pals run Sherco's to get a "shot" of a good one to try out)
#7 copemech
    Advanced Member
  • Site Supporter
  • 8,053 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 09 August 2008 - 09:38 PM
Sounds as though you ave just about covered everything else!
Seems as though I resall some place online selling scooter parts for vespa's or something selling those ducati coils cheap, a google search perhaps?
try linky
Edited by copemech, 09 August 2008 - 09:45 PM.
#8 mark1161
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:Montesa 4RT
Posted 11 August 2008 - 09:14 AM
Copemech - I had a look at the web link you sent, the coil on the Sherco has an extra 3 wires than the ones shown on the website !!!!! I think it will have to be a genuine Sherco part
I also found something very similar on the JK Hirst website for £25..... but it still doesn't have enough wires - is this some sort of programmeable CDI unit on my pal's bike ?
#9 copemech
    Advanced Member
  • Site Supporter
  • 8,053 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 11 August 2008 - 11:51 PM
If you look at the pic in the linky, there are terminals on the coil pack for a red, white, green and black wire as I recall. The yellow is earth from the coil, then you have the secondary coil wire to the sparkie. These may be epoxied in on the factory unit.
I no longer have an older one around to look at first hand.
Doubt you have anything programmable. :thumbup:
#10 mark1161
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:Montesa 4RT
Posted 12 August 2008 - 07:13 AM
I definitely have more wires - I have the earth (green) and a red, white and another green (all from one connector) from the loom coming from the stator, I also have another set of wires from the stator (blue, brown and black I think) with a seperate connector whch also goes into the coil and the HT lead which comes out of the coil. All eight wires are epoxied into the coil unit.
I forgot to add earlier that it's a Leonelli system on my bike.
Edited by mark1161, 12 August 2008 - 07:19 AM.
#11 copemech
    Advanced Member
  • Site Supporter
  • 8,053 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 13 August 2008 - 02:42 AM
Sounds basically the same as my '07, so Leonelli. My '02 bike was Ducati, did not think they changes till '03, yet who knows.
Last shot for other info would be Steve
#12 copemech
    Advanced Member
  • Site Supporter
  • 8,053 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 13 August 2008 - 02:55 AM
I suppose I have gone brain dead, as I thought there were published diagrams on the Sherco wireing with specs, yet I cannot find them for Leonelli.
Hello Wayne, do we have this info? :thumbup:
#13 mark1161
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:Montesa 4RT
Posted 21 August 2008 - 11:20 AM
Finally got it sorted - it looks like what may have happened is that when the trigger on the stator packed in it damaged the coil at the same time, so both have now been replaced and the bike is up and running again
Thanks for all the help (especially from Russell W.) and suggestions from everyone
Edited by mark1161, 28 August 2008 - 11:29 AM.
