My son has took the step of starting trials and we have managed to get a really tidy 125 (02) off of ebay for £750. Bike runs well, the seller allowed me a test ride before taking the money off me, threw in a brand new set of rear plastics!!!!! and told me about the one know fault which is a poor rear brake. TOP BLOKE!
A few questions for the masses to guide me on............
1) Having been out of trials myself since the late 80's, I am now sure of the modern servicing schedules for the modern bikes ? Whats normal ?? My son is planning to compete probably twice a month. I read of people doing full oil changes every 4 events ? What is "normal" ?? to keep these bikes in good spirits
2) Whats the fuel mix for an 02 125 ? I can not see a separate tank so I assume its premix straight into the tank ? If so what is the ratio
3) Regarding the rear brake, the previous owner has bled it, but whilst it just grabs, its not enough to lock the wheel on the flat, let alone a down hill stretch? I was looking for the rear fluid tank ? Where is this ? I assume its under the rear mudguard plastics when these come off ?
4) Where would you start with the rear ? I dont reckon the calipers have had a good service, so I was planning a full strip of the rear caliper but is their any other quick wins / checks first
Any help / advice would be appreciated
(Looking forward to getting him started...........then Im allowed to buy one for meeeeeeeeeeee!)
Rob
Sherco 125 02
Started by slogger, Jul 26 2008 03:41 PM
7 replies to this topic
#1
Posted 26 July 2008 - 03:41 PM
#2
Posted 26 July 2008 - 04:23 PM
Rob
Rob
There is a lot of info for you hereclicky link
If you have good pressure on the rear pedal yet not stopping well, first thing to do is steam clean it! Do this bu first making a few hard stop attempts to heat the disc, then quickly douse with bottle water. You may do this two or three times to get it to steam off clean. Nothing wrong with that brake when working properly you know.
Ride it Like it was one of your old Girlfriends, If you still remember how!
#3
Posted 27 July 2008 - 04:23 PM
Copemech,
many thanks, loads for me to read thru there! will try the steam cleaning as the first step. Never heard of that technique before but it sounds logical.
Struggling to get a hold of the fuel mix ? Whats the ratio or volme in uk for petrol to oil ??
Also, have given the bike a good look over today and whilst practicing balancing on a light hill, noticed some play/knocking on the front set up. Thought it was the steering head bearing or maybe the forks at first, but traced it to the front disc. With the front brake on, the pads are holding the disk solid but the disk itself is moving on the hub bolts. I assume this has never been replaced and the holes have ovaled off hence the movement? Should their be any play there or should it be solid ??
Rob
Rob
#4
Posted 27 July 2008 - 10:20 PM
What you have on the front is a "Floating Disk" it is supposed to be that way.
Not sure of the reasons or benefits for it but that's what is also on my 2000 2.9 Sherco.
fuel mix I run is 80:1 full synthetic oil. Seems to be the most popular in 250 and up, not sure about 125's.
"You can't fix stupid...but it will heal (eventually)"
#5
Posted 28 July 2008 - 03:16 AM
You see, Zippers nuts are a bit looser than some, but he is basically correct as there is some clearance there that may be noticed when stationary. Do be sure to inspect the retaining bolts on both front and rear discs though, and be sure they have some locktight(blue) thread sealer on them. Keep snug, yet do not overtorque these small bolts.
The 80:1 ratio is widely accepted, using good synthetic oil. As an easy out, you may run the Yamalube 2R semi-synthetic which seems redily available from Yamaha in a pinch.
80:1 = 62.5ml per 5L as i figure, check that quick figure, as I am still having a metrically challenging hangover! Ha!
Unless the rear pucks are saturated with oil or something they may well come back to life. The biggest difference from the later bikes is the dual pot front caliper as compared to the newer quad. The dual still works, and I would clean it as well, the same way!
After the things dry, you may see an immense change in performance, and if they start making noise, this can be even better! Then they are working!
#6
Posted 06 August 2008 - 09:48 PM
All,
many thanks for the advice. Have had a go at bleeding the rear first (seeing as the guys said he had done it). Got to the airbox and found a bodged cross threaded allen bolt! No way he had bled it! Spent 10 mins and already it is better. Will try the steam clean as that sounds a good step forward and will spend a bit more time bleeding all of the system (just done the caliper end).
Front disk is a wierd one. Have "floating" discs on my Ducati but these are more a connector between the hub assembly and the rotor. I have no play on these. The Sherco definately has loads of pay that I would say is excessive. Am planning to have a look this weekend. My hunch is that they holes have gone oval over time as the play is definately at the hub point. I would be surprised if the amount of play is "normal".
#7
Posted 07 August 2008 - 12:26 PM
The play is definatly normal.My 04 seems exessive,but i believe it like that to stop the disk from fracturing when brake is fully on and front shocks are then fully compressed (like maybe a heavy landing)Sounds wierd but somebody will no doubt tell me i am a k**b!
Wembley...i was there!!!!
#8
Posted 08 August 2008 - 06:30 PM
