Carburetor Fuel Screw For Beta Rev4
dennisgr
I am sure it isn't have the same carburetor but they are both Mikuni and it might have the same thread and the same tip on the fuels screw so that I could use it after modifying. If you follow the link there are pictures of the Scorpa 125 original and a CMX fuel screw next to a ruler with millimeter scale. I modified the CMX fuel screw to fit. The thread M6x0.5 was right but the tip was too different so the adjustments range was not right. So what I wonder now is if the Beta Rev4 fuel screw is a better candidate for modifying or not. From the not so good pictures I have seen of it it seems too short so would have to lengthen the stem. Just as long as the thread and tip is right it should be doable.
Edited by DennisGr
