Gas Gas
9 replies to this topic
#1 slack
    Member
  • Members
  • PipPip
  • 96 posts
  • Bike:05 GasGas 300 raga
  • Club:Consett
Posted 12 October 2008 - 05:48 PM
Hi everybody, I'm would like to know what is the best gearbox oil to put in my 05 280 gasser.Some of my mates are using ATF but i'm not sure what is best.I used to use Motul 10/30 in my Scorpa sy would this suit the Gasser or is it to thick.THANKS.
#2 Greg
    Advanced Member
  • Members
  • PipPipPip
  • 340 posts
  • Bike:delibrating
  • Club:ping k15 driver, callaway razr x irons, taylor made putter
Posted 12 October 2008 - 06:29 PM
ATF is fine.
#3 JanDyb
    Advanced Member
  • Members
  • PipPipPip
  • 244 posts
  • Bike:280 Pro Racing 2011
  • Club:Trøgstad Trialklubb, Norway
Posted 12 October 2008 - 07:28 PM
 Greg, on Oct 12 2008, 08:29 PM, said:
ATF is fine.
ATF yes and preferrable "Dexron III" I think.
If not ATF you should use 10/40 pure mineral oil. Not synthetic.
-Jan
#4 jsp
    Advanced Member
  • Members
  • PipPipPip
  • 328 posts
  • Bike:2012 OSSA T280i
  • Club:West of leeds, Horsforth, Spen Valley, Huddersfield
Posted 12 October 2008 - 07:32 PM
i have just changed my gearbox oil on an 08 raga, and on peterb's recomendation
i have got 4.55lits of carlube atf dexron III from my local car shop for £17.50 and
now you can see the oil through the clear window
jsp
#5 Greg
    Advanced Member
  • Members
  • PipPipPip
  • 340 posts
  • Bike:delibrating
Posted 13 October 2008 - 04:29 PM
jsp
4.55 litres,how much did you put in?
#6 jsp
    Advanced Member
  • Members
  • PipPipPip
  • 328 posts
Posted 13 October 2008 - 05:28 PM
550ml just like the manual said
#7 PeterB
    Advanced Member
  • Members
  • PipPipPip
  • 650 posts
  • Bike:OSSA TR280i
  • Club:Waitemata
Posted 15 October 2008 - 07:53 AM
Hi jsp,
500 ml is fine, any extra may exit out the breather pipe, not that it causes a problem though.
A straight mineral 10 weight works well, I wouldn't use the 10/40 mineral, tends to cause the clutch plates to drag.
Bye, PeterB.
#8 slack
    Member
  • Members
  • PipPip
  • 96 posts
  • Club:Consett
Posted 16 October 2008 - 02:10 PM
Hi everybody,thanks for all your'e re-plys i have asked a lot of people about this.I phoned my local trials shop White Bros at Darlington & spoke to Al-the Spanner & he recomended i use Motul 300v fully synthetic. So i phoned GASGAS UK & they said this oil was ok to use.What AL said was that ATF was ok but with the gearbox oil lubing the mains they found the Motul to be the better oil to use. M
#9 JanDyb
    Advanced Member
  • Members
  • PipPipPip
  • 244 posts
Posted 16 October 2008 - 08:11 PM
Now I am a little confused. In this document:
http://www.trialspartsusa.com/diagrams/Pro...2013%202008.doc
It says wery clear that synthetic oil should not be used:
I quote
"Oil type warning:
Never use synthetic oil in the transmission~clutch. The synthetic oils are “stickier” and this adhesion tendency, when applied to the areas between the clutch plates contribute to excessive clutch drag. Some brands of synthetic oil will chemically react when mixed with water, (from creeks, rain, or waterpump seal leakage). This reaction alters the pH factor of the oil. This acidic condition accelerates corrosion of steel engine parts, and loosens the bond of the clutch fiber plate material. Please do not second-guess this information. We have twelve years of experience with the Herbringer/Adige brand clutch plate materials, and we are in direct contact with the technical departments at Herbringer, Adige, and GASGAS Spain."
Doesn`t this apply no more?
-Jan
#10 JanDyb
    Advanced Member
  • Members
  • PipPipPip
  • 244 posts
Posted 03 November 2008 - 08:53 PM
I quote
"Oil type warning:
-Jan
I never really got a reply to this?
-Jan
