You have not picked the most forgiving bike to start out on! The 280 can be a bit of a handful compared with the 240, but what is done is done. I used to have a 91 280R and found that the motor was pretty bulletproof, in fact apart from regular servicing I never had to touch it. The weak point on the bike I found was the front forks, namely the seals. After the original set started to leak I never succesfully found a set that really lasted any length of time. Thought I'd sussed it once as I found that the sliders were oval when measured but even a new set never really cured the problem. They are also a little on the heavy side compared to othre marques of a similar vintage, whilst in fact this may not be the case on the sclaes it certainly felt like it! You can also change the characteristics of the motor by playing around with different rotary valves. Over the years they changed the shape a few times and I accumulated quite a collection of different ones, you can even move them on the spline and again alter the way the motor delivers it's power
You don't mention where in the world you are but if the USA I found the Tryals Shop to be very helpful
This post has been edited by peter9000uk: 11 May 2009 - 08:42 AM
