Rev 3 Mixture Screw
yamahaty250xox
Gday, basic rule rule for mixture screws is - if it is on the inlet manifold end of the carb, screw in for leaner (usually around 2.5 turns out from seated). If it is on the aircleaner side of the carb screw out for leaner (usually around 1.5 turns from seated fully). Check the aircleaner is not dirty or over-oiled before you play with it.
HTH
Cheers,
Stork
