09 Sps Carb For 320
6 replies to this topic
#1 gregrsv
    Member
  • Members
  • PipPip
  • 31 posts
  • Bike:EVO 250
  • Club:Lochaber and district
Posted 15 February 2009 - 05:12 PM
Hi guys
Does anyone know how much the 09 sps carbs are , im going to fit one o my 07 model to see if it improves the starting?
Also anyone done similar things any feedback would be much appreciated.
cheers greg
#2 copemech
    Advanced Member
  • Site Supporter
  • 8,055 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 16 February 2009 - 03:43 AM
Wayne put one on his earlier model and mentioned the price was about $500 usd! Still the hot setup! :D
Ride it Like it was one of your old Girlfriends, If you still remember how!
#3 Neo
    Advanced Member
  • Members
  • PipPipPip
  • 920 posts
  • Bike:250 2006 (07 frame)
Posted 16 February 2009 - 09:45 AM
What the hell is in a Carb that makes it worth $500 usd!???
Best of balance.
Neo
My Bike ....www.trialscentral.com/forums/garage/vehicle/516-sherco-250-2t-racing-red/
TRIALS....It's not life or death....It's much more serious than that!!
#4 Wayne Thais
    Advanced Member
  • Members
  • PipPipPip
  • 268 posts
Posted 16 February 2009 - 12:06 PM
The SPS carb is designed to eliminate hesitation when you whack the throttle, has nothing to do with starting.
I do not know about the 07 but on the 08 the pilot circuit is critical for good starting, set the idle up and set the air screw, if it is the Keihin carb at 1/2 to 3/4 turns out.
Wayne
#5 gregrsv
    Member
  • Members
  • PipPip
  • 31 posts
  • Bike:EVO 250
Posted 16 February 2009 - 10:28 PM
Thanks guys
The reason i was asking is because the 320 i have has been modified with a bigger flywheel and the addition of a 24mm oko ,
ive mucked about with pilot scre adjustment and needle , etc but the symptoms dont seem to change much , i'd like to put a carb std to the bike on it to get to a decent starting point to see if it eliminates this starting issue .
I am nearly at the stage of getting rid of the bike for something that starts , but its saving grace is when it is running its a great bike , with brilliant low down power and very easy to get grip in most instances.
if i can isolate this problem by trying the proper carb i'll be keeping 4t for sure!
greg
#6 sirhc
    Advanced Member
  • Members
  • PipPipPip
  • 566 posts
  • Bike:Scorpa SR 280
  • Club:Southern California Trials Association
Posted 17 February 2009 - 02:24 AM
I've had both an 07 & now an 09 3.2 and they both started with no problems. The SPS carb makes the bike run a little nicer, but the 07 ran pretty darn good to.
If your bike has a different carb that would surely be your starting issues and shouldn't be blamed on the bike. You should be very happy with the bike if you get the proper SPS carb.
Edited by sirhc, 17 February 2009 - 02:26 AM.
Chris Cullins
#7 gregrsv
    Member
  • Members
  • PipPip
  • 31 posts
  • Bike:EVO 250
Posted 26 February 2009 - 09:12 PM
I bought an 09 style carb from the sherco dealer i fitted it today and instant improvement is apparent on the starting issues ive been dogged with hot or cold its max a couple of kicks so thats great , ive even tried it up hill stalling and downhill and it still goes first or second kick ,
its a lot sharper off the bottom end than when it had the 24mm oko fitted , but i ' drather that than a bike you cant start half the time.
I still have the larger flywheel conversion fitted as i have not got an original flywheel or casing to try , but i think i'll just run with that , if anything i think the increased flywheel effect will be softening the power off the bottom end and help prevent stalls in low speed stuff .
One thingi have noticed at the top end its a hell of a lot more powerful the little oko carb must have been strangling the bike something terrible.
cheers for all your ideas and comments
greg
I think i'll hang on to this bike now! by the way 300 quid in the uk for an SPS carb not cheap , but in my case well worth it!!
