2009 Ragas, Good Or What ?
#1
Posted 17 February 2009 - 10:33 AM
#2
Posted 17 February 2009 - 04:30 PM
#3
Posted 17 February 2009 - 05:53 PM
#4
Posted 17 February 2009 - 06:18 PM
#6
Posted 17 February 2009 - 09:01 PM
steveo, on Feb 17 2009, 04:33 AM, said:
I had a chance to ride the 08' 250 Raga some time ago and found it very easy to adapt to quickly. Some bikes I've ridden seem like I have to slightly force them to do something, but the Raga, with the new frame, just reacted to my input without protest. Almost like thinking it makes it so. Very well balanced and it had me confidently looking for obstacles that would have been slightly above my talent level riding my 280 Pro. I would have liked a slightly shorter turn radius, but that would easily be acomplished with a minor mod to the fork stops.
The Raga, along with some special additives that are Raga specific, usually incorporates the changes that will appear in the next years production bikes (like the new 28mm tube frame).
Jon
#8
Posted 17 February 2009 - 10:02 PM
#11
Posted 19 February 2009 - 05:18 PM
laser1, on Feb 18 2009, 12:10 PM, said:
Wrong, they were 09 Raga's, saw my first one in the back of Munch's van last May.
#12
Posted 19 February 2009 - 05:46 PM
PERCE, on Feb 19 2009, 05:18 PM, said:
Wrong May 2008 were 08 Raga Reps, May 2009 will be 09 Raga reps
The 08 Raga is based on the 09 model TXT Pro but is an 08 model.
Every Raga model since inception in 2003 has been a taster for the next years model with with the exclusion of the magnesium parts, keihin carb, and Ohlins shock (older models) etc
The little gold plate on the bike will say '08 - XXX' the XXX being the production number as they are limited run models
#13
Posted 19 February 2009 - 06:31 PM
Thats correct, my new in May Raga 250 says 08 on the gold plate and key ring.
#14
Posted 20 February 2009 - 04:05 PM
So does mine... But back to the thread: My 250 is so easy to ride, but I have had lots of problems getting it to run OK at tick-over and its still not right, but it carburates beutifully through the rest of the rev range. I have heard that the Keihin carb can be a bit fickle but this is taking the p**s. Titty pipe is very thin and already looks very 2nd hand (i.e dinged on the bottom bend), but rest of bike quality is fine.
#15
Posted 22 February 2009 - 03:30 AM
I have a 300 Raga, previously had an 06 Raga 300 and an 04 300 before that. This latest model has by far the most torquiest engine of my 300's. Carburation was lean and needed a larger main jet plus , for me, runs best with a GJH needle. I preferred the 06 model for riding feel, the 08 feels as though the footrests are a little high and quite a long ways back. The plastic triple clamp to frame protector restricts steering lock and feels much better with it removed. Gearing is higher than 06/07 models, even with a 10T gearbox spkt, but is just fine for me with a 10/44 combination and now feels like the 06 bike. I ended up making up a set of footrests that were 10mm lower and this feels a lot better. I fit the Hebo flywheel weight and this is great for riding up rocky creeks (becks, burns).
As it is, the bike is bril and hard to improve upon, better than my 06 Raga even.
By comparison, I had a ride on an new Evo 290, felt like riding a plank after the Raga with a heavy and on/off clutch action, still, other riders like them.
Bye, PeterB.
