Headstock Bearing Help!
4 replies to this topic
#1 tombo46
    Advanced Member
  • Members
  • PipPipPip
  • 534 posts
  • Bike:2008 Gas Gas 300
Posted 24 February 2009 - 12:12 PM
Ive been changing the steering bearings and found the bottom on was absolutly nackered. problem is its so nackered that its seperated itself from the inside race which is now stuck. any ideas how to get it off? tried WD40, heating it up but it just doesnt want to budge!
Tom
If toast always lands butter side down, And cats always land on their feet, What would happen if you buttered a cats back?
#2 B40RT
    Advanced Member
  • Site Supporter
  • 2,553 posts
  • Club:Stevenson, Perth & District, Edin' St George.
Posted 24 February 2009 - 12:42 PM
http://www.trialscentral.com/forums/index....showtopic=23822
Cleaning a section is like setting fire to Joanna Lumleys shoes.
#3 JSE
    Advanced Member
  • Members
  • PipPipPip
  • 2,024 posts
  • Bike:Gas-Gas Pro, TY350s
  • Club:NEOTT-Life member, Texhoma Trials Club, AMA-Life Member
Posted 24 February 2009 - 03:13 PM
Tom
Tom,
There is a special puller, the bad news is you have to make it yourself :(
I've cut the inner race diagonally with a Dremel and a thin abrasive wheel and then used a chisel and a sharp rap with a steel hammer to split the race, but using a MIG or TIG to quickly weld a piece of metal to the race to lever it off works well. The heat has to be quick and localized so the aluminum is not damaged. I would imagine that the shaft could be pressed out of the lower tripleclamps (and then pressed back in) to lever the race up/off but that might be a last resort.
Jon
#4 mcman56
    Advanced Member
  • Site Supporter
  • 405 posts
  • Bike:Rev3, Reflex
  • Club:PITS
Posted 24 February 2009 - 03:22 PM
I have used carbide end mills in a milling machine to cut a groove in the inner race. Once the wall thickness is very thin, it will split with a little force. It was surprising how easy the races machine with carbide tools.
#5 tombo46
    Advanced Member
  • Members
  • PipPipPip
  • 534 posts
Posted 24 February 2009 - 04:53 PM
I was surprised how easily it split too, I ground it down with a small cutter on my air compressor, then when it was thin, used the flat edge id ground out to get a grip on it. and bobs your real dad, it cracked =]
Thanks for the help
Tom
