Fantic 200 Choke Problem
#1
Posted 05 March 2009 - 11:54 PM
#2
Posted 06 March 2009 - 11:06 AM
Lee
#3
Posted 11 March 2009 - 07:33 PM
Cheers Russell
#4
Posted 11 March 2009 - 08:36 PM
My crank seals were new also.....
did you put exactly 1000cc oil in it? Try and ride it for about 15 mins, smoke and all. Then drain the oil. If you have less that 1000 cc,s its a crank seal. mine smoke like a steam train and used 400cc oil in 4 sections. It smellt terrible also...ATF does not burn well.
Is the carby ok whats jets are in it?
lee
Edited by Lee Harris, 11 March 2009 - 08:38 PM.
#5
Posted 11 March 2009 - 09:50 PM
I will let you know how i get on, Cheers Russell
PS just bought a 303 today aswell to add to the collection.
#6
Posted 15 March 2009 - 12:18 AM
when running it the problem was still there, althogh it did seem alot better bottom end, its as soon as you are in 3rd, 4th and 5th and it just has no response and is basically spluttering along but again no excessive smoking or nasty noises, Could it maybe be electrical? I remember when puuting the flywheel back on that the pick up did not sit exactly square and I needed to put a little block of plastic behind it, just to kind of prop it up so that it would sit in line and enable it to get a spark, sounds dodgy I know but it worked perfectly like that many years ago and it wasnt until after the recent rebuild that i came across it and remembered why it was there, Cheers Russell
Ill send an email tomorrow regarding the 305 spindal,
#7
Posted 15 March 2009 - 07:56 AM
L
Edited by Lee Harris, 15 March 2009 - 07:59 AM.
#8
Posted 15 March 2009 - 08:56 PM
#9
Posted 15 March 2009 - 10:07 PM
#10
Posted 18 May 2009 - 10:39 PM
I am having my WES silencer re-packed also and getting the front pipe back this week so it has not been tried and tested but I am sure this is the cure to my problem.
WATCH THIS SPACE AS RESULTS WILL BE POSTED ASAP
Cheers
#11
Posted 26 May 2009 - 09:45 PM
C'Mon guys help me here, its got to be carb ??? What else could it be?
Russ
#12
Posted 27 May 2009 - 10:55 AM
Older carbs are often very dirty in the small passages.
If you did not clean the carb completely you could try ultrasonic cleaning.
The best way to find out if it is the carb O.K. or not is to switch for another one (borrow/buy?).
That way you know for sure.
And is the carb you are using at this moment the right carb for the Fantic 200?
Good luck,
Arie from Holland.
#13
Posted 27 May 2009 - 11:09 AM
#14
Posted 31 May 2009 - 10:24 AM
#15
Posted 31 May 2009 - 10:29 AM
Good luck,
Arie from Holland.
Hi Arie,
I had the carb out so many times and cleaned it with an airline also, the carb is def the correct one.
Ive taken your advise and bought a 2nd hand one and will try that or will give Martin (shazsdad) a buzz and borrow his.
I hope this is the answer!!!
Cheers Russ
Edited by RussellD, 31 May 2009 - 10:30 AM.
