Replacing Shock Absorber Bushes
3 replies to this topic
#1 Eugheugh
    Member
  • Members
  • PipPip
  • 27 posts
  • Bike:Greeves 250 TAS
  • Club:none
Posted 16 April 2009 - 07:21 AM
Can anybody please tell me how to get the rubber bushes back into the eyes of the shocks ?. They were removed before I bought them from a vendor at a jumble.
Cheers
#2 alan
    Advanced Member
  • Members
  • PipPipPip
  • 141 posts
  • Bike:shuttleworth snap
  • Club:peppermint rhino
Posted 16 April 2009 - 10:02 AM
I am not familiar with greeves shocks... but general engineering good pratice would suggest, ( assuming every thing is the right size) :-
Make sure there is a good lead (chamfer) on the hole and maybe even consider grinding a small chamfer onn the leading edge of the bush.
Lubricate well with soapy water ( the soap will wash away over time - oil can attack rubber especially if it is the wrong grade (epdm)) and squeeze together in your vice. The rubber may spring back a little when you undo the vice so you may need to use a couple of appropriately sized sockets to position the bush correctly.
Edited by alan, 16 April 2009 - 11:04 AM.
trying something new is like taking the first steps to failure
#3 B40RT
    Advanced Member
  • Site Supporter
  • 2,553 posts
  • Club:Stevenson, Perth & District, Edin' St George.
Posted 16 April 2009 - 02:13 PM
Alans sounds like an engineer. Bodgers way, which generally works, vice, bush, tighten vice. May need a socket for the last bit.
Cleaning a section is like setting fire to Joanna Lumleys shoes.
#4 charlie prescott
    Advanced Member
  • Members
  • PipPipPip
  • 808 posts
  • Bike:bsa Otter's Etc,
Posted 16 April 2009 - 08:20 PM
Hi Guy's.
Yes Alan's way is right,but if you have not got a vice to hand ,you can do the job with a couple of big washers a length of threaded rod ,with two nuts and spanners, and socket or a short peice of tube.
Regard's Charlie.
