Page 1 of 1
200 Tech Info info on rear wheel gearings and fork oil seals.
#1
Posted 24 April 2009 - 07:51 PM
Does anyone know the size of the bearings needed for the rear wheel on a 200?
Also why has my 200 got 2 oil seals in the front forks? Is this a benefit, are there any imrovements that i can make to there operation?
Ta.
Steve
Ta.
Steve
#2
Posted 24 April 2009 - 08:09 PM
Has one of the seals got a pring round it? If so its just a dust cap
#3
Posted 24 April 2009 - 08:36 PM
All early fantics up til 240 and even some 300s had 2 seals each side. The 300/301 forks had one and a dust seal although two can be fitted here also. If you can make teflon bushes turn them for 0,08-0,1 mm clearance and bin the second seal. If not, dont worry. The forks will suffer from a little stiction but are still better than most bultos, ossas and tys. Only the tlr forks are better me thinks....
Lee
Lee
This post has been edited by Lee Harris: 24 April 2009 - 08:37 PM
I swear to drunk I'm not God!"
#4
Posted 24 April 2009 - 08:38 PM
oh sorry bearings are either 6302, or 6203 cant remember which. I think the latter
#5
Posted 24 April 2009 - 08:43 PM
The number is on the edge of the bearing, you might need a magnifying glass to see it if you are as old as me. think its a 6203 17x40x12
Ron
Ron
#6
Posted 01 May 2009 - 03:12 PM
The way you ride you may aswell use a bit of 22mm copper pipe rammed in the hole
That is if you are THE somerset steve the coin only just dropped..
"To many bikes is not enough"
#7
Posted 06 May 2009 - 08:27 PM
Ta Dicker.
At least i make an effort to enter a section through the start and not the end gate!!!!!!
#8
Posted 07 May 2009 - 08:38 AM
Somerset Steve, on May 6 2009, 09:27 PM, said:
Ta Dicker.
Ok you got me on that one, Still never mind , A bad days riding is better than a good watching..
Share this topic:
Page 1 of 1
Help
