Bike: 2006 TXT Pro 125 Racing with 40mm Marzocchi alu forks.
Yes I have read the document here http://www.trialspar...a.com/tech.html but there it says:
1. Disassemble the superior cap of each suspension leg.
...ok no problem.
2. Remove the spring.
..ehh now it becomes difficult. I cant find a way to remove the spring.
Ok so I loosen the allen bolt at the bottom and withdraw all the "stuff" inside. Out comes -surprisingly easy - everything inside and also surprisingly it sticks together with no loose parts - spring and all. Ok so the tubes are loose and let me clean them out. Something that was very needed as "someone" had painted the springs with a kind of paint that dont withstand oil. Result is that the bottom of the tubes were full of red paint particles. Why paint the springs anyway??
Cleaned out and got it together again no problem. But how much oil to put in. The "measure level" method wont work as the springs are not out, but now I know the tubes are absolutely empty. The document says 230cc left and 130cc right, but can I trust this as the other things dont work?
-Jan
Edited by JanDyb, 09 July 2009 - 08:32 PM.
