Trials Central: Delorto Carb On 280 Txtedition - Trials Central
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Delorto Carb On 280 Txtedition Rate Topic: -----
#1 User is offline   bowershall
  • Member
  • PipPip
  • Group: Members
  • Bike:gas gas 280
Posted 29 July 2009 - 07:15 AM
Hi
I am having a little problem with my 2002 TXTedition 280. The engine can be very slow to return to idle. Sometimes it does not idle properly, cutting out.
After removing and cleaning the carb it runs better but soon returns to the previous state. On stripping the carb again it seems to be clean. If I build it up then start it, it runs ok for a while.
Any ideas?
New airfilter, plug fitted. Checked for air leaks at manifold and base gasket etc.
Gordon
This post has been edited by bowershall: 29 July 2009 - 07:32 AM
#2 User is offline   benz19
  • Advanced Member
  • Group: Site Supporter
Posted 29 July 2009 - 08:41 PM
Sounds like you have an air leek,or in other words ,the engine is getting air from somewhere else than the carb.
Most common place is ignition side crank case oil seal,remove cover and check for oil in the ignition area,you may have to remove rotos and stator to be sure.
Other area to check is reed block for sealing.
Benz.
#3 User is offline   bowershall
  • Member
  • PipPip
  • Group: Members
  • Bike:gas gas 280
Posted 30 July 2009 - 04:21 PM
Thanks, will check crank seal. Have already checked the reed valve block etc.
Just seems strange that after cleaning the carb, it runs ok for a while. I think that if it was the crank seals, then carb cleaning would have no effect.
Gordon
#4 User is offline   PeterB
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:OSSA TR280i
  • Club:Waitemata
Posted 31 July 2009 - 01:09 AM
Hello Gordon,
It may be due to a partially blocked petrol tap, petrol cap vent not working, fuel filter clogged in the DellOrto carb, throttle slide sticking, or maybe you have vent pipes on the carb vents that are connected together and not venting to atmosphere. Does sound like mag side oil seal though you say the motor is fine for a while after the carb is cleaned out, have a check on the above.
Bye, PeterB.
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
