Help, need thread size for a broken bleeder valve on the rear brake....
Page 1 of 1
Rear Brake Bleeder Valve thread size?
#1
Posted 31 July 2009 - 05:32 AM
#2
Posted 31 July 2009 - 09:40 AM
If your bike is a GasGas, the thread is 10 x 1.0 .
You can see it on this link:
http://www.ajpameric...-and-parts.html
Saludos
Saludos
GasGas Contact TXT 270 1999
Beta Rev3 2005
GasGas Contact JT-25 1994
Mecatecno Dragonfly 50 (Cilindro 74cc, Dell'orto 21)
GasGas Contact T-25
Beta Rev3 2005
GasGas Contact T-25
#3
Posted 01 August 2009 - 12:20 AM
Hello APK,
If you are talking about the rear caliper bleed nipple, this thread is M6 x 1.0 (6mm diameter, 1mm pitch) The pre PRO models have a larger nipple arrangement.
If it has seized in place, be real careful when drilling out that you are precise in getting your 5mm tapping drill exactly in the centre, also you need to know how deep to go as the end of the nipple has a bevel surface that seats up against a similar bevel inside the caliper. Best to measure the new nipple first to gauge the drill depth so as not to cut past the origina bevel in the caliper.
Bye, PeterB.
Bye, PeterB.
#4
Posted 03 August 2009 - 05:24 AM
Mecajental and PeterB, thanks for all your help!! I`ll let you know how its goes !!
Share this topic:
Page 1 of 1
Help
