Txt 125,can It Be Made Into A 200 Or 250?
5 replies to this topic
#1 dabomb
    Advanced Member
  • Members
  • PipPipPip
  • 150 posts
  • Bike:sherco
Posted 02 August 2009 - 06:38 PM
Is it possible to change an 03 txt pro 125 into a 200 or even a 250,just by changing the barrell an piston??
Cheers
Edited by dabomb, 02 August 2009 - 06:38 PM.
Wembley...i was there!!!!
#2 John.B
    Advanced Member
  • Members
  • PipPipPip
  • 352 posts
  • Bike:GasGas 250 2010
  • Club:Middlesbrough, Guisborough & Richmond & Eboracum
Posted 02 August 2009 - 06:45 PM
Think there is a conversion kit from Gasgas uk to take it to 225cc. New head, barrel and piston.
#3 Funtrials
    Advanced Member
  • Members
  • PipPipPip
  • 129 posts
Posted 03 August 2009 - 05:10 AM
A GasGas dealer/mechanic told me today that 225 is the maximum (from 125.) Thinking about one for family member, in the future.
#4 crasher
    Member
  • Members
  • PipPip
  • 87 posts
  • Bike:gasgas
  • Club:estc,pboro,pegasus
Posted 03 August 2009 - 07:04 AM
225 conversion kits cost around £600 i think, i bought a second hand 200 barrel and piston ( which is actually 163cc i think) same carb and jetting, also need to weld a flywheel weight on to stop it stalling so easy, leave out the plastic crank inserts from the 125 barrel as well, there is a noticeable increase in the power from that extra 40cc and it makes a nice useable bike
#5 MIKEE
    Advanced Member
  • Members
  • PipPipPip
  • 294 posts
  • Bike:Sherco 320 4t
  • Club:launceston /Torridge & district mcc
Posted 03 August 2009 - 08:43 AM
Why have you left out the plastic crank insert ???
Does this make any differacne to the running of your bike???
#6 crasher
    Member
  • Members
  • PipPip
  • 87 posts
  • Bike:gasgas
Posted 03 August 2009 - 03:56 PM
i was told that if you leave the inserts in it makes it too fierce, the power delivery is like an on off switch, it's a bit like that if you don't put a flywheel weight on as well, i'm sure there are other people on here that can give you the proper technical description, something to do with reducing the crank volume too much for the bigger piston or something like that
