Fantic 240
2 replies to this topic
#1 poornebbing
    New Member
  • Members
  • Pip
  • 6 posts
Posted 09 August 2009 - 09:35 PM
hello there i have just bought a really tidy and original 240 from germany unfortunately as the engine warms up the top end develops a really loud knock and i dont know what the problem is can anyone help? also she wont return to tickover very quickly and tickover speeds up when hot??
#2 htrdoug
    Advanced Member
  • Members
  • PipPipPip
  • 262 posts
  • Bike:Fantic 240
  • Club:Trials Inc.
Posted 20 August 2009 - 12:07 AM
Air leak causing a severe detonation(Pinging,Pinking) Can sound like a metal to metal knock when really bad,think big Diesel truck type noise.Best to do a pressure test.The Idle issues are a clue.If it passes a pressure test it's possible the ignition has gone wonky and timing is advancing.be careful 'cause it can go into runaway,I had a 440 Maico do that to me while it was loaded into the back of my pickup truck,yanked the plug wire,still screaming away,jammed it into gear,just started doing a burnout in the truck bed,didn't get it shutdown until I had shifted up into high gear and stood on the rear brake pedal...
Fantic 240,Fantic 309
Yamaha TY350,back home!
2011 Sherco 250
2009 Kawasaki KLX250S DualSport
#3 poornebbing
    New Member
  • Members
  • Pip
  • 6 posts
Posted 26 August 2009 - 07:32 PM
thanks htrdoug ,but can you tell me how to check the timing on a 240 fantic,can i use a lamp or is it static timing only?
