Trials Central: No Spark 2005 Txt 280 Pro - Trials Central
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
No Spark 2005 Txt 280 Pro Rate Topic: -----
#1 User is offline   dluck
  • New Member
  • Pip
  • Group: Members
  • Bike:GasGas
  • Club:NMTA
Posted 11 August 2009 - 08:26 PM
Hi, I am having problems with my ignition system and was hoping maybe someone could help.
I just recently purchased a lightly used 2005 TXT 280 PRO from a friend. I brought the bike home and proceeded to go through the bike make any necessary adjustments and change all fluids. After all the maintenance was completed I washed the bike with the tank off, spraying the bike with a garden sprayer attached to my hose at home. I then reinstalled the tank on the bike after drying it off. Now the bike will no longer start. I checked for spark and there is none. How do I go about checking the ignition system on this bike? I assume it is one of the following components: stator, ignition controller box, pickup coil, or ignition coil. Any advice?
#2 User is offline   laser1
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:09 GG 250
Posted 11 August 2009 - 11:13 PM
I would spray all under tank connections and plug hood with WD40 and try again.
#3 User is offline   dluck
  • New Member
  • Pip
  • Group: Members
  • Bike:GasGas
  • Club:NMTA
Posted 12 August 2009 - 02:33 PM
I figured it out last night. It was a loose ground wire. The ground running into the CDI had pulled out of the plug slightly and was no longer making contact. The bike runs great now!
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
