Rear Tyre Inflation
41 replies to this topic
#1 Jonathan Collier
    Member
  • Members
  • PipPip
  • 54 posts
  • Bike:'07 GG 200Pro
  • Club:Vale of Towy Dyfed Dirt Bike Club
Posted 18 August 2009 - 05:18 PM
Any tips on getting a new rear tyre to seat on the bead? I can't get the air to catch the tyre and pop it onto the rim.
#2 The Addict
    Advanced Member
  • Members
  • PipPipPip
  • 2,862 posts
  • Bike:Dirty Donna
  • Club:none yet but working on it
Posted 18 August 2009 - 05:21 PM
you taken the valve out
#3 jimw
    Member
  • Members
  • PipPip
  • 62 posts
  • Bike:Beta Evo 250 2010
  • Club:Horsforth, Scarborough,West Leeds
Posted 18 August 2009 - 05:23 PM
loads of tyre soap and a yomee tyre beader ( I have seen it done with a long rag but much easier with the beader) - then take valve inner out and get some psi in.
Some people try a tie-down strap around the tyre circumference but I don't find it works.
regards
Jim
#4 JanDyb
    Advanced Member
  • Members
  • PipPipPip
  • 244 posts
  • Bike:280 Pro Racing 2011
  • Club:Trøgstad Trialklubb, Norway
Posted 18 August 2009 - 05:35 PM
This works! Did it yesterday.. :lol:
-Jan
#5 4ourtea
    Member
  • Members
  • PipPip
  • 76 posts
  • Bike:4RT & Evo 250
  • Club:numerous Western + Wessex
Posted 18 August 2009 - 06:04 PM
You could also try a push bike inner tube (marginally inflated) jammed in on one side between the tyre and rim.
Take valve inner out -
Whack in the air (I've had to go higher than stated on tyre wall) - bead on non tube side comes out first
Keep pumping air in - tube side then locates
Slowly reduce the tyre pressure and ease the inner tube out from between the now-seated bead and the rim.
Works every time for me...
I don't like using the soap because I feel it stays "slippy" - fine for getting it onto the rim, but also a danger the tyre will slip off more easily in a section or big impact/twist. If you are struggling, even a little water can sometimes be enough to do the last bit.
Happy tyre-flashing...
#6 Pete_Scorpa3
    Advanced Member
  • Site Supporter
  • 1,440 posts
  • Bike:Scorpa SY250
  • Club:Stratford-Upon-Avon MC&LCC
Posted 18 August 2009 - 06:07 PM
Push bike inner tube between the tyre bead and the rim.
You do have to be quick to pull it out as the tyre inflates otherwise it gets caught and you have to start again but with practice, this works really well.
I've still got the same push bike inner tube after ten years or more.
#7 1oldbanjo
    Advanced Member
  • Members
  • PipPipPip
  • 173 posts
  • Bike:2009 Sherco 3.2
  • Club:None
Posted 18 August 2009 - 06:40 PM
If you are bold.......you can try this method!
Good luck!
#8 Nigel Dabster
    Advanced Member
  • Members
  • PipPipPip
  • 6,570 posts
  • Bike:Gas Gas Bultaco 340
  • Club:Milton Buzzard MCC,Richmond MC
Posted 18 August 2009 - 06:45 PM
-Jan
not always it doesn't
#9 Nigel Dabster
    Advanced Member
  • Members
  • PipPipPip
  • 6,570 posts
Posted 18 August 2009 - 06:48 PM
Much cheaper but if you get a real difficult one on a saturday night before a trial you will be more than happy you have the beader in the shed!!!
#10 Jonathan Collier
    Member
  • Members
  • PipPip
  • 54 posts
Posted 20 August 2009 - 03:47 PM
Thanks for all the tips guys. It's putting up a good fight alright, we've got it to take pressure now but can't quite get the last bit of bead to seat on the rim, it's not popped into place. Tyre markings says max 33psi which is a bit of a joke, how high can I go with the pressue without killing myself? :lol:
#11 Nigel Dabster
    Advanced Member
  • Members
  • PipPipPip
  • 6,570 posts
Posted 20 August 2009 - 04:07 PM
if its near and wont pop on are you using lubricant? I have gone to 80 but 60 is more common with lube on a difficult one.
#12 The Addict
    Advanced Member
  • Members
  • PipPipPip
  • 2,862 posts
  • Bike:Dirty Donna
Posted 20 August 2009 - 04:34 PM
As Andrew says 60 pound plus and it should double pop on then, never had one go on less than 50 pound yet and as much as 80 plus sometimes
#13 B40RT
    Advanced Member
  • Site Supporter
  • 2,554 posts
  • Club:Stevenson, Perth & District, Edin' St George.
Posted 20 August 2009 - 06:25 PM
80 psi on a tube type rim, and as soon as you let it down it pops right back off ?
Cleaning a section is like setting fire to Joanna Lumleys shoes.
#14 MIKEE
    Advanced Member
  • Members
  • PipPipPip
  • 294 posts
  • Bike:Sherco 320 4t
  • Club:launceston /Torridge & district mcc
Posted 21 August 2009 - 02:16 PM
85 psi is as much as i've ever gone to with a dunlop...
35 psi with the mich x light i've just put on.
Loads of lube is the way to go if its close as you say...
#15 B40RT
    Advanced Member
  • Site Supporter
  • 2,554 posts
Posted 21 August 2009 - 03:42 PM
View PostNigel Dabster, on Aug 21 2009, 07:04 AM, said:
Tubeless.
I must not deviate from the topic, even minutely.
