This is an open letter placing down my curiosity as to the realty of my thoughts of two vs four stroke traction. It is looking at the theory vs reality.
Given that a two stroke crank rotates (under power) with every pulse of the spark plug means that every rotation of the crank is under power and therefore no free wheeling in affect. The pulses are somewhat smooth as there is no coasting just continuous power being sent to the back wheel as long as you have the clutch out and the gas on.
A four stroke on the other hand has the crank make one revolution without a power pulse and one with. Basically the crank is coasting with no power pulse for one revolution and one with. This mean that when you have the gas on and clutch out on a four stroke it theoretically pulses and coast as the crank turns.
This in theory should give less traction and/or smoothness as one has lost a smooth constant grip with the ground not thru the coasting but when the power comes back on and tries to turn the back wheel.
It is more of a on off affect to power in the world of trials and smooth constant traction.
The two stroke is always trying to power or pulse the wheel as the crank is constantly under power.
I wonder how all of this relates in reality to traction as the theory says it has less traction due to its pulsing.
I welcome any input to this thought as all indications are that the bike gets great traction
Maybe I have answered my own question as the on and off again is the secret to why it gives more traction.
Two stoke= One bit of gas equals one power crank turn pulse.
Four stroke = A bit of gas gives one power crank turn and one coast crank turn. Hmmmm...........
BillyT
Edited by BillyT, 04 December 2004 - 06:45 AM.
