2006 125 Vibration
10 replies to this topic
#1 manwithtool
    Member
  • Members
  • PipPip
  • 82 posts
  • Bike:Beta 250 Rev3
  • Club:Berkhamsted MCC
Posted 21 September 2009 - 09:02 AM
We finished a trial on Sunday, and my son stayed and had another 20 minutes practice. But came back complaining of vibration thru the handlebars. He insists he did nothing unusual !! but 14 yr olds say that alot !
Anyway, it does seem to be vibrating a bit more than I'd expect. Seems to be running fine no misfire. I wipped the stator cover off and there doesn't seem to be any play in the mains bearing. I haven't looked at the clutch side yet, but if that was worn I'd assume it would suck in gearbox oil and smoke alot. And I'm guessing a main bearing wouldn't go just like that ? could it be a big end ? I recently (5 trials ago or more) replaced the piston and rings and top end. No play in big end then.
Anyone got any clue what might have caused a sudden increase in vibration ?? anything appreciated !!
Cheers
Martin
#2 manwithtool
    Member
  • Members
  • PipPip
  • 82 posts
Posted 21 September 2009 - 01:58 PM
Just an update...
I called MRS and spoke to a helpful chap who said it is most likely to be the rear bash plate bolt come undone....So I'll be checking that tonight. be nice if it was that simple....although bolting a bash plate on is never much fun !
cheers
#3 B40RT
    Advanced Member
  • Site Supporter
  • 2,554 posts
  • Club:Stevenson, Perth & District, Edin' St George.
Posted 21 September 2009 - 09:52 PM
A slack engine mounting bolt (even half a turn) can cause vibration.
Cleaning a section is like setting fire to Joanna Lumleys shoes.
#4 manwithtool
    Member
  • Members
  • PipPip
  • 82 posts
Posted 22 September 2009 - 10:15 AM
I hope so because the bash plate looks ok. I know there's a bracket from the barrel to the frame under the tank. I had to remove this to replace the piston, the allen bolts into the frame were a pig to remove, so maybe there were done up tight for a reason...I'll see if they have come undone tomorrow night....I'll check all bolts !!
#5 Kramit
    Advanced Member
  • Members
  • PipPipPip
  • 286 posts
  • Bike:Kram-it
  • Club:scta
Posted 23 September 2009 - 01:59 AM
Front motor mt. bolt is my guess
#6 manwithtool
    Member
  • Members
  • PipPip
  • 82 posts
Posted 25 September 2009 - 09:03 AM
Well I had a look the other night and the bolt going thru the bracket on the rear of thebarrel was loose. Too late to start the bike up...But hopefully this will cure it.
Cheers for all the help !
#7 manwithtool
    Member
  • Members
  • PipPip
  • 82 posts
Posted 28 September 2009 - 08:05 AM
B*gger.... Vibration is still there. I have been informed that a loose or wobbly flywheel might be the cause....I'll take alook at this tongiht hopefully with a dial gauge. I checked bfore and there was no play, but I didn;t try and "wobble " it.
I'll also go over all engine mounting bolts with a spanner rather than just check with my fingers. Trial on Sunday so I hope it's a quick and easy fix !
#8 trialsnutterman
    Advanced Member
  • Members
  • PipPipPip
  • 281 posts
Posted 28 September 2009 - 09:13 AM
Yeah defiantly check all bolts will a spanner socket, don't forget the swingarm axle hidden under the plastic caps.
#9 manwithtool
    Member
  • Members
  • PipPip
  • 82 posts
Posted 28 September 2009 - 08:59 PM
Well, I went round and tightned up all bolts, bash plate bolts although not loose I could tighten them about 1 turn. Same for the Front engine mount. However I think I have made a big mistake by startin the bike up on the bike stand....on it's wheels it doesn't seem to vibrate too bad...Anyone else care to confirm that a bike will vibrate alot more on a solid stand ?
fingers crossed !! I suspect it was the bolt at the rear of the barrel not helped by the others not being that tight.
Cheers for all the help and advice !
#10 copemech
    Advanced Member
  • Site Supporter
  • 8,055 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 29 September 2009 - 01:33 AM
Sounds normal for that to me, I think you have it fixed! :)
Ride it Like it was one of your old Girlfriends, If you still remember how!
#11 manwithtool
    Member
  • Members
  • PipPip
  • 82 posts
Posted 12 October 2009 - 07:21 PM
Yep all fixed....I suspect it was the bolt on the back of the barrel.
Cheers all....
But I have had anther problem....But I'll start another post..
Cheers
