Switch To Sherco From Beta
Started by paul w, Oct 11 2009 09:53 AM
7 replies to this topic
#1
Posted 11 October 2009 - 09:53 AM
Hi all, i am considering swaping from a 2008 beta rev 3 to a 290 sherco 2009 model (new). the last 290 i rode was a 2003 model that to be fair was in pretty poor condition. at the time i didnt think it was comparable. has anyone else made this switch? any know problems with this model? am i better off with a 250 or 290 sherco? thanks in advance , Paul.
#2
Posted 11 October 2009 - 10:27 AM
don't you fancy an evo?
#3
Posted 11 October 2009 - 11:53 AM
No regular problems I've heard of with later Sherco's. In fact I would dare to say they are pretty reliable!
From 2008 onwards the 250's are sold in UK in 'UK tune' as requested by MRS.
Most riders choose the 290 but I suspect few have actually ridden the later 250's.
Which you choose depends on your skills, also fitness as the 290 can be tiring, your own weight and the type of sections you ride, 250's are rarer then 290's.
I did ride an Evo 250 at a Steve Saunder's test day and I thought it was quite a decent bike. After a Sherco I found the steering lock extreme.
Like the Raga Replica Gassers there is usually a 'Replica' Sherco 290 each year (Cabestaney Replica or Racing R), these are usually a bit quicker still and more expensive.
#4
Posted 11 October 2009 - 04:12 PM
250 is
Ride it Like it was one of your old Girlfriends, If you still remember how!
#5
Posted 11 October 2009 - 06:10 PM
Quote
#6
Posted 12 October 2009 - 05:21 AM
Dabster you know better than put teasing ads in the forums.....deleted
Edited by Slapshot 3, 12 October 2009 - 05:22 AM.
I keep telling people I'm in shape....round is a shape
Be schizophrenic, you'll never be alone.
You are the one who is blind and connot see the truth in the world. You live sheltered in a monastry of your hate, and cannot admire beauty and truth while I snort the cocaine of excellence and bang the hooker of awesomeness. - Wonderlance
#7
Posted 12 October 2009 - 12:30 PM
Hi, After 4 years of Rev3 250's I recently bought a discounted new Sherco 290. I'm no expert but here are my findings so far. It;s true the Sherco doesn't have as much steering lock but I have a couple of practice sections with tight turns that I could only just manage on the Beta and I'm still managing them with the Sherco so it might not be as much of an issue as expected. The 290 does take a bit more holding onto but in the 3 trials I've done on it if I've found that I'm less tired on it than I would've been on the Beta. I might try a slow action throttle but the fast one isn't bad ,although it does get to a point where it suddenly delivers big power.
To me it also seems much easier to move around the front and back wheel in sections. The Sherco also uses much less fuel (I wonder why)
and sometimes I no longer bother topping up between laps now. I guess I lost faith in Beta's after my 07 needed mains/seals through no fault of my own at 16 months old and that along with a new Evo costing me almost £900 more made it an easy decision for me. Hope some of that helps.
#8
Posted 12 October 2009 - 04:22 PM
I have recently changed my bike, moving from a 07 270 Beta to a new 290 Sherco. I enjoyed my beta but I fancied a change and fell to the temptation of price.
Before riding the Sherco I removed the excess wiring and fitted a decent kill switch, its easy pull out the loom to expose the connected wires, cut it free, join the two yellow wires together, the black goes to one side of the kill switch. The union between the plastic tank and the rear mud guard is awful, I improved this slightly by unbolting the coil and bending the coil mount down to lower it as the tank pressed on coil, it’s still not that good though.
First ride.
I have always run bikes in properly bringing them up to “fan on” temp then give them a rest to cool, repeat etc, don’t labour the engine initially. Straight away the 290 was much quicker off the mark than the beta. I rode my 1st trial with it in standard trim, it was too quick for me, and the problem was exaggerated by lack of available free play in the throttle cable.
2nd time out I changed to a slow action throttle, I am not sure I liked the action but it helped though not enough.
Big thanks now to my old friend Mick from M sport. I felt the bike was too quick for me, any suggestions? He had one, check your pilot jet; contrary to what it says on the maintenance down load my bike had a very lean 30 pilot jet fitted, not a 33 as it says in the book. Apparently some dealers change the jet at PDI, but mine had not been. Having heard that a slightly larger than standard jet may be preferred I fitted 34. Different bike altogether and now much more to liking, I may even put the quick domino back on.
Other positives include ease of maintenance. The course in gynaecology and Anglo Saxon I took to enable me to remove and replace the carb on the Beta is wasted on the Sherco, it’s a five bolt two jubilee clip job to remove tank, guard, air box and carb – it all falls back into place. Air filter has been clean so far.
First ride.
