Steering Head Bearings
hoodie2
can anyone tell me what size ball bearings would fit the original steering head bearings of an M92? Building up from bits and want to reduce costs and re use the standard bearings for now, but the balls are missing. Also what mods are needed to accomodate tapered needle roller bearings?
Cheers
Hoodie
There is only one "gotcha" with these conversions. The Sherpa has a lot of angular offset between the headstock and forks so you should not deviate too far from the original yoke mounting distance to avoid alignment problems.
The original bearing set had a total length of 12mm, some of the conversions use modified 32005 bearing which have a assembled length of 15mm. there is one set I have seen with correct diameters but still a lenth of 14.5mm. So for 2 bearings the yokes are 5 or 6 mm further apart. That difference is almost all the total thickness of the preload adjuster nut.
Just trigged this out based on a 2 deg offset, and it may not be too siginificant actually, 6mm futher apart would equate to about just over 0.2mm or 8 thou misallignment. Only other issue is possibly the extra height may not be shrouded well by the original pressed bearing shrouds, and adjuster nut.
Wayne.....
Edited by wayne_weedon
Hi all, just received some taper roller bearings today which are the right size( bore25mm dia 45mm width thickness 12mm)got these off pyramid parts adverting in classic dirt bike . (WWW.PYRAMID-PARTS.COM) TEL 01387 269985 (
Edited by hewson
Wayne.....
I noticed this when I fitted these bearings to my model 221. I slipped an '0' ring over the lower headstock and when the forks were re-assembled I rolled the 'o' ring into contact with the bottom shroud. This shroud faces up anyway diverting anything liquid into the bearing, however, next time I serviced the bearing they were the cleanest and water/muck free I have ever seen them so all my bikes now have an 'o'ring in this position.
I fitted some of these taper roller bearings over 2 years ago on my 199B .......... :thumbup:
Yep, I have them in all mine too - The Miller conversion used a thicker bearing but those from Pyramid are the same dimensions as the original as far as I recall.
