Help Help Help Help Help !
7 replies to this topic
#1 cal1892
    New Member
  • Members
  • Pip
  • 8 posts
Posted 22 February 2010 - 12:15 PM
ok, i have a gas gas txt 2001,
just redone the waterpump seal the clutch basket the clutch plates resealed the front case and flushed the rad, filled it with coolant and it is now leaking coolant out of the overflow pipe from the rad.
any ideas ?
#2 houseape1000
    Advanced Member
  • Members
  • PipPipPip
  • 416 posts
  • Bike:03 SY250
  • Club:Guy Fawkes fan club
Posted 22 February 2010 - 12:40 PM
How much is it leaking, and does it leak more at higher revs, also does it leak when hot or cold or both ?
Does it gush out or does it drip.
Check the valve in the rad cap, this is some advice I got last week and hey presto.......sorted.
What is that private Pyle ? Sir, a jelly doughnut, sir!
What is your major malfunction, numbnuts?
#3 Pete_Scorpa3
    Advanced Member
  • Site Supporter
  • 1,440 posts
  • Bike:Scorpa SY250
  • Club:Stratford-Upon-Avon MC&LCC
Posted 22 February 2010 - 12:42 PM
Check that the seal is properly in place onthe cap. Then run the bike for a while and see if the flow from the pipe stops, it's likely that this is simply the coolant finding it's correct level.
#4 cal1892
    New Member
  • Members
  • Pip
  • 8 posts
Posted 22 February 2010 - 12:58 PM
it seems to gush out as im riding as in the seal you mean the thinest of the thinest rubber on the end of the cap? ive checked this and it seems ok, bike also running quite hot.
where can i get a new seal ?
#5 lineaway
    Advanced Member
  • Members
  • PipPipPip
  • 343 posts
Posted 22 February 2010 - 09:39 PM
If it is running hot is the fan rotating?
#6 cal1892
    New Member
  • Members
  • Pip
  • 8 posts
Posted 22 February 2010 - 10:01 PM
fan is not running constant but the cylinder head and exhaust are hot, fan has been on before though
#7 smalley250
    Advanced Member
  • Members
  • PipPipPip
  • 487 posts
  • Bike:Gas Gas 250
Posted 23 February 2010 - 07:20 AM
Replace the bike :rolleyes:
#8 cal1892
    New Member
  • Members
  • Pip
  • 8 posts
Posted 23 February 2010 - 02:02 PM
ha if only,
