Tlr 250 Cutting Out When Running Fast Between Sections
7 replies to this topic
#1 bobtlr
    Advanced Member
  • Members
  • PipPipPip
  • 366 posts
  • Bike:sherco 3.2 tlr 250
  • Club:KAMCE Torhout
Posted 07 April 2010 - 08:18 PM
Hey,
my tlr cuts out when running fast between sections if the distance is more than 2 km. it cuts out and stalls and after 5 sec it starts again and runs fine
no problem when riding sections or when driving slowly.
could it be that my sparkplug gets to hot? should i use a diferent plug for long trials?
best regards bob
#2 Stork955
    Advanced Member
  • Members
  • PipPipPip
  • 564 posts
  • Bike:Beta Evo 250 2010
  • Club:Tasmanian Motorcycle Trials Club
Posted 07 April 2010 - 08:48 PM
Gday, I assume you are using wide open throttle for a longer period here, so it is probably a fuel supply issue. Check for some restriction in the fuel supply - part blocked filter on the tap, kink in the hose etc, part blocked breather or possibly incorrectly set float drop. This is the adjustment tang on the float that allow the float to open fully, not the one that sets the float height and touches on the needle. A quick test is to run the carb pipe into a bottle etc and open the tap. You should see a strong continuous flow for as long as there is fuel in the tank. If not - look for the problem.
Cheers,
Stork
#3 bobtlr
    Advanced Member
  • Members
  • PipPipPip
  • 366 posts
Posted 07 April 2010 - 09:27 PM
i didn't tought about that, i'll check it asap tnx for the tip
#4 max1956bikes
    Advanced Member
  • Members
  • PipPipPip
  • 256 posts
  • Bike:hondas
  • Club:nene valley
Posted 08 April 2010 - 10:48 AM
i agree with stork.fuel starvation
#5 bobtlr
    Advanced Member
  • Members
  • PipPipPip
  • 366 posts
Posted 08 April 2010 - 03:25 PM
hey,
fuel seems fine, the bike revs out well and sounds sweet, when riding a mile or 2 fast the engine stops like you would push the kill switch
after some seconds it runs perfect again.
i checked the fuellevel in the carb, fuel lines and the carb all seems fine
what sparkplugs are u using?
best regards bob
#6 motomike
    Advanced Member
  • Members
  • PipPipPip
  • 154 posts
  • Bike:RTLR260, RS250 / 360
  • Club:Stringfellows
Posted 08 April 2010 - 07:43 PM
[quote name='bobtlr' date='Apr 7 2010, 09:18 PM' post='234051']
Hey,
best regards bob
Bob
as others have suggested ,sounds like lack of fuel, are you running a standard tank,or one of the fibreglass one piece units?
#7 TLTEL
    Member
  • Members
  • PipPip
  • 87 posts
  • Bike:tlr200 tl125 g g 350
  • Club:folkestone trials
Posted 08 April 2010 - 09:18 PM
Hi Bob
Just a thought did you check the tank breather in the cap, make sure you are not getting a vacuum in the tank as the fuel is used quickly.
It does sound like a fuel problem.
TLTEL
#8 bobtlr
    Advanced Member
  • Members
  • PipPipPip
  • 366 posts
Posted 08 April 2010 - 09:35 PM
hey,
i use a stock steel tank and the hose is not blocked
the bike works great but only 1 trial a year i have those problems, i clean the cooling fins after each section becorse i know the 250 doesn't like it when the engine gets to hot
regards bob
