Sorry I'm being really lazy here, can someone confirm that normal brake fluid is ok in a sherco. I understand Gagas need mineral oil ?
Also are there any specific anti freeze solutions I need to use. I tend to use the pink long life stuff in cars as it has better anti corrosion properties. Currently seems to have some blue stuff in it.
Thanks
Page 1 of 1
Anti Freeze And Brake Fluid
#1
Posted 10 May 2010 - 08:42 AM
#2
Posted 10 May 2010 - 11:19 AM
Normal DOT 4 brake fluid will be fine in the Sherco.
Bultaco - Built To Go
#3
Posted 11 May 2010 - 02:26 AM
Thanks
Thanks
Personally, I tend to stay away from the pink and orange long life coolants in the bike. Some of that stuff has nasty residues. I do not neccessarily think the corrosion resistance is better, just lasts longer, but not an issue in the bike as I drain mine annually. One thing for sure, don't mix them! And use distilled water when mixing your batch as it in itself helps things get along nicely.
Ride it Like it was one of your old Girlfriends, If you still remember how!
#4
Posted 11 May 2010 - 11:00 AM
All sounds like good advice...Many Thanks
Share this topic:
Page 1 of 1
Help
