Argh It Wont Rev Out!
11 replies to this topic
#1 TJP
    Member
  • Members
  • PipPip
  • 37 posts
  • Bike:gas gas 250 txt pro
Posted 13 May 2010 - 07:33 PM
Hi Guys,
I have an 08 250 sherco which I love. It starts easily, idles great, it pulls smoothly from low revs through into a nice usable mid range and then it all goes wrong!. The bike absolutely refuses to rev out, its as though it hits a rev limiter!. I have made sure jetting and fuel/oil ratios are correct, fitted a new plug and ensured all electrical connections are clean and tight.
Has anyone got any ideas as to what I can try next?, I feel its going to be an electrical issue but was hoping it isn't the stator!
Thanks in advance for any advice/ideas
#2 mcman56
    Advanced Member
  • Site Supporter
  • 405 posts
  • Bike:Rev3, Reflex
  • Club:PITS
Posted 13 May 2010 - 07:39 PM
What does it sound like and run like when it hits that limit?
#3 TJP
    Member
  • Members
  • PipPip
  • 37 posts
Posted 13 May 2010 - 07:48 PM
It sounds like the revs are bouncing, a bit like when someone is revving a cold bike that hasn't warmed up properly and I guess it feels a little like that too. It stops pulling and as a result I need to carefully evaluate any climbs and pick taller gears that I wouldn't normally
#4 t-shock 250
    Advanced Member
  • Members
  • PipPipPip
  • 963 posts
Posted 13 May 2010 - 07:52 PM
Sounds like a carburation issue.
#5 TJP
    Member
  • Members
  • PipPip
  • 37 posts
Posted 13 May 2010 - 08:05 PM
Thats what I thought but I've stripped and cleaned the carb and used the jetting recommended by Rathmells with little/no improvement. I have also tried larger main jets as I thought it could have been fuel starvation but had no change in the characteristic of the bike
#6 Stork955
    Advanced Member
  • Members
  • PipPipPip
  • 564 posts
  • Bike:Beta Evo 250 2010
  • Club:Tasmanian Motorcycle Trials Club
Posted 13 May 2010 - 08:07 PM
Gday - is the air inlet restricted in some way? - over oiled filter for example? Your exhaust should be reasonable at this age but it might pay to have a look in there as well. Maybe repack the muffler at least.
Cheers,
Stork
#7 TJP
    Member
  • Members
  • PipPip
  • 37 posts
Posted 13 May 2010 - 08:13 PM
Cheers,
Stork
Cheers Stork, I'll check these out
#8 thespikeyone
    Advanced Member
  • Members
  • PipPipPip
  • 648 posts
  • Bike:Scorpa 250 R
  • Club:RAFMSA
Posted 13 May 2010 - 09:21 PM
when does it do it, from cold or when hot????
have you checked fuel breather on tank.
I had similar problem but it only happened when fan came on, it was the little black fan voltage reg, only a couple of quid.
JOIN THE RAF THEY PAY YOU TO RIDE TRIALS!!!!! - (EVEN IF YOUR NOT THAT GOOD) http://www.raf.mod.uk/careers/
It's like being a factory rider but you drink more beer and your score doesn't matter.
#9 copemech
    Advanced Member
  • Site Supporter
  • 8,057 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 13 May 2010 - 11:27 PM
What size main jet is in it? Does it have stock reeds?
Do you cary a spare coil in your backpack?
Edited by copemech, 14 May 2010 - 01:30 AM.
Ride it Like it was one of your old Girlfriends, If you still remember how!
#10 ZIPPY
    Advanced Member
  • Members
  • PipPipPip
  • 1,829 posts
  • Bike:2000 Sherco 2.9
  • Club:Team WGASA, Bent Fenders
Posted 14 May 2010 - 08:09 AM
Never leave home without one, I carry a spare coil for everything I own.
Coil of electrical wire.
coil of tape
coil of rubber bands
coil of film (old school not that fancy digital HD stuff)
coil of mechanics wire
Just gotta be prepared :thumbup:
"You can't fix stupid...but it will heal (eventually)"
#11 TJP
    Member
  • Members
  • PipPip
  • 37 posts
Posted 16 May 2010 - 09:23 AM
Hey guys, I'VE FIXED IT!!!!!, thanks for the advice,
Just thought you'd like to know what was causing this mysterious issue. As I said before the bike started and ran fine except at high rpm, where it wouldn't rev out. Well after going through the jetting, checking timing, rebuilding the engine and checking ALMOST every terminal for cleanliness and corrosion, I thought I’d disconnect the stop switch. The bike now revs to the moon!!, couldn't believe it. There was a reasonable amount of corrosion in the switch closing the gap to the contact and I guess at higher revs, the more intense vibration caused the contact to touch!
Oh well, thanks again, I'm off to enjoy my new revvvvy toy
#12 copemech
    Advanced Member
  • Site Supporter
  • 8,057 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 18 May 2010 - 03:22 AM
Well, that is indeed of interist! And yes, I suppose if one was gunkey it could indeed cause problems. :rolleyes:
