Trials Central: Heres One For You 4rt Experts! - Trials Central
  • 2 Pages +
  • 1
  • 2
  • You cannot start a new topic
  • You cannot reply to this topic
Heres One For You 4rt Experts! 4rt wont start Rate Topic: -----
#1 User is offline   johnfromscarborough
  • Member
  • PipPip
  • Group: Members
  • Bike:2011 gasgas
  • Club:SDMC
Posted 14 May 2010 - 09:10 PM
Right did oil change on bike all went well went to start bike and nothing checked every thing. good spark fuel pump works bypassed tilt switch still nothing, have another 4rt swapped all bits over and nothing my bits work on other bike fine. :thumbup:
my bike is a 2005 model well serviced well looked after other bike is a 2006 mode got us both stumped.
Both handy with spanners.
Got us well stumped :thumbup:
Changed condenser
changed rectifier
#2 User is offline   Pete_Scorpa3
  • Advanced Member
  • Group: Site Supporter
  • Bike:Scorpa SY250
  • Club:Stratford-Upon-Avon MC&LCC
Posted 14 May 2010 - 09:17 PM
Stuck/bent/very tight valve maybe?
#3 User is offline   johnfromscarborough
  • Member
  • PipPip
  • Group: Members
  • Bike:2011 gasgas
  • Club:SDMC
Posted 14 May 2010 - 09:33 PM
got good compression though?
no nasty noise coming from the engine
#4 User is offline   houseape1000
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:03 SY 250R
  • Club:Guy Fawkes fan club
Posted 14 May 2010 - 09:58 PM
You should always check the coil first......apparently !
(sorry)
What is that private Pyle ? Sir, a jelly doughnut, sir!
What is your major malfunction, numbnuts?
#5 User is offline   johnfromscarborough
  • Member
  • PipPip
  • Group: Members
  • Bike:2011 gasgas
  • Club:SDMC
Posted 14 May 2010 - 10:13 PM
done that other wise they wouldnt be a spark,
new plug lead and cap to............ :thumbup:
#6 User is offline   albert
  • Member
  • PipPip
  • Group: Members
  • Bike:scorpa
Posted 14 May 2010 - 11:22 PM
Exhaust bung ? always gets me. checked all connections? fuel pump? Did you let caseing hang or did you unplug. Kill switch.?
#7 User is offline   jonny042
  • Member
  • PipPip
  • Group: Members
  • Bike:GG 280 09
  • Club:UMTA/CMA
Posted 15 May 2010 - 12:22 AM
Changed condenser
changed rectifier
My memory is fuzzy on this it's been a while since I did the oil change on mine but do you have to remove the side cover and disrupt the wiring in the region?? I think the pickup for the ignition is in there so it might be worth a look.
You might also try hooking 12v supply to the electrical system and disconnect the rectifier, then try to run the bike on external power. to isolate any potential problems with the charging/elect system and you could also check the current draw with the bike "at rest" to ensure there are no shorts to ground.
#8 User is offline   sutty
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:mclaren alta suzuki
Posted 15 May 2010 - 06:06 AM
this is a primative way to iliminate what the problem is take the spark plug out and put a little bit of petrol down the plug hole put the plug back in and kick it over to see if it starts if it does you know its a fuel problem if it doesnt then you know its possably electrical it is primative but it works good luck
#9 User is offline   johnfromscarborough
  • Member
  • PipPip
  • Group: Members
  • Bike:2011 gasgas
  • Club:SDMC
Posted 15 May 2010 - 06:38 AM
Checked fuel tank on other bike works fine,
no bung allready out,
johny, would there still be a good spark though checked all wiring,
only thing didnt check was fuel injector going to try that now see how that goes
#10 User is offline   fantic303
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:Cota 4RT
Posted 15 May 2010 - 07:11 AM
Hi check your gascable the throttle must be 100% closed, try agin with some space on the cable.
#11 User is offline   Pete_Scorpa3
  • Advanced Member
  • Bike:Scorpa SY250
Posted 15 May 2010 - 10:12 AM
(sorry)
And I wonder who you are trying to wind up there? :thumbup:
#12 User is offline   Big John
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:Various
  • Club:Inverness & District
Posted 15 May 2010 - 10:34 AM
I always take the view if you have only done one thing to a bike and it won't start, what was the last thing you did/changed? Thta will be the root cause!
Obviously changing the oil and filter will not be directly involved with a no-start.
However, disconnecting the electrical supply plug and not reconnecting it properly will have an effect, as will a throttle cable pulled out of its moorings, this will decline a start as the bike will be in unsafe mode! Did you have the bike keeled over and inadvertantly pull out the cable?
Was there anything else you did to the bike other than change the oil and filter?
Big John
"A Gentleman can never have too many motorcycles"!
Highland Classic 2 Day Trial (UEM) 9/10 June 2012, Alvie Estate, Aviemore, Scotland..."The Friendliest and Biggest Classic Trial in Scotland" ™!!
"Just Shut-Up and Ride!"
On any Sunday, I'm a flyin' Man!
and finally...It's just my personal opinion!
#13 User is offline   jonny042
  • Member
  • PipPip
  • Group: Members
  • Bike:GG 280 09
  • Club:UMTA/CMA
Posted 15 May 2010 - 01:40 PM
I guess maybe swap ecu/throttle body from/to other bike?? You're right about the spark, that should eliminate pickup and or power issues. Unless not enough juice to run fuel pump and injector. Spark doesn't take much energy, but the pump/injector might.
I'm with Big John on this one, maybe the throttle cable!!!
#14 User is offline   johnfromscarborough
  • Member
  • PipPip
  • Group: Members
  • Bike:2011 gasgas
  • Club:SDMC
Posted 15 May 2010 - 01:53 PM
thanks so far for the advice,
Throttle body has been swapped works fine on other bike,
injector pump is pumping fine.
throttle cable is slack enough.
just checked all valve clearences all fine.
going back to a spark issue just pulled cap of and tried the lead against the head the spark is a bit erratic, as in not there every kick and quite poor on some kicks... :thumbup:
could houseape1000 be correct cheked this first had a spark then moved on. :thumbup:
Should you be able to get a spark by using your hand to kick it?
#15 User is offline   albert
  • Member
  • PipPip
  • Group: Members
  • Bike:scorpa
Posted 15 May 2010 - 04:33 PM
Did you say you linked out the bank angle sensor? which cables did you link? how much oil did you put in?
Share this topic:
  • 2 Pages +
  • 1
  • 2
1 User(s) are reading this topic
