Trials Central: Sherco 320 4t Decompresser... - Trials Central
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Sherco 320 4t Decompresser... Rate Topic: -----
#1 User is offline   MIKEE
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:Sherco 320 4t
  • Club:launceston /Torridge & district mcc
Posted 03 June 2010 - 09:01 AM
Has anyone taken the auto decompresser off there 08 320 4t....????
Now i lernt to start the bike i can't rellay see a lot of point in have it on the bike and it makes a lot of noise....
I've got a top end gasket set and i'll be checking the sims soon, so if the decompresser is not needed and easly removed with know ill
efects then i will remove...
Cheers mike
#2 User is offline   1oldbanjo
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:2009 Sherco 3.2
  • Club:None
Posted 03 June 2010 - 12:35 PM
This topic was discussed about 4 months ago in this thread: http://www.trialscentral.com/forums/index....showtopic=29383
You might contact the fellow that removed his decompressor and see how it has worked for the last 4 months.
#3 User is offline   bobtlr
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:sherco 3.2 tlr 250
  • Club:KAMCE Torhout
Posted 03 June 2010 - 03:30 PM
Hey,
i'm running my bike without the decompressor and it works fine.
no more rattle at low revs and starts very good. it needs a good prod but it works ok
best regards bob
#4 User is offline   1oldbanjo
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Club:None
Posted 03 June 2010 - 04:04 PM
So why do you think the decompressor was added? Most manufacturers try to avoid adding parts that are not necessary - both to save cost and to eliminate potential problems. Was it added just to help old guys like me kick the bike over?
#5 User is offline   bobtlr
  • Advanced Member
  • PipPipPip
  • Group: Members
Posted 03 June 2010 - 10:02 PM
yep thats why decompressers are used, and to make life easier for kickstarts, shafts and so on
but if you start your bike like you should there are no problems, if you start jumping on the kickstart then it will not last long
best regards bob
#6 User is offline   copemech
  • Advanced Member
  • Group: Site Supporter
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 04 June 2010 - 04:00 AM
I think them things are a rather novel little device! You can actually prod that big bore 4t through with a slow gentile methodical prod and it will light off!
The proper ritual for those motors without can be a bit of a drill, yet does still work! Has for ages anyway!
I was a bit surprized a few weeks ago to find one in a large single cyl lawntractor motor of about 19HP! Seems it gave the little electric starter some relief! :rotfl:
Ride it Like it was one of your old Girlfriends, If you still remember how!
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
