Trials Central: Front Wheel Loose ? - Trials Central
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Front Wheel Loose ? Rate Topic: -----
#1 User is offline   swinny
  • Member
  • PipPip
  • Group: Members
  • Bike:montesa 315
Posted 06 June 2010 - 07:09 PM
hi, i have got a 1999 mont 315 and the front wheel seems to be loose, even when the spindle and bolts are tight ? there is only one spacer on the wheel (at the disk side i think). should there be a spacer at the other side ? or is there somethng else missing...... looked in the manual i have and the pictures are that bad i cant tell, cheers matt
#2 User is offline   spitfirepilot423
  • New Member
  • Pip
  • Group: Members
  • Bike:Sherco
Posted 06 June 2010 - 07:32 PM
Sounds like wheel bearings need to be replaced.
#3 User is offline   swinny
  • Member
  • PipPip
  • Group: Members
  • Bike:montesa 315
Posted 06 June 2010 - 07:37 PM
ok cheers for this information i will get the checked as i dont know what to do. do you know if there should be more than 1 spacer as it seems the wheel moves from side to side slightly
#4 User is offline   spitfirepilot423
  • New Member
  • Pip
  • Group: Members
  • Bike:Sherco
Posted 06 June 2010 - 07:59 PM
Not sure about spacers in Mont. With the front wheel off the ground, hold wheel firmly at 12.00 and 6.00 o'clock. Try to rock the wheel from side to side and check where the movement/knock is coming from. A missing spacer would allow the wheel to move along the axle (with the brake caliper removed), rather than rattle on the axle.
#5 User is offline   swinny
  • Member
  • PipPip
  • Group: Members
  • Bike:montesa 315
Posted 06 June 2010 - 08:05 PM
just checked it as you said and seems as if the bearing is fine, it moves from left to right on the spindle about 4mm
#6 User is offline   spitfirepilot423
  • New Member
  • Pip
  • Group: Members
  • Bike:Sherco
Posted 06 June 2010 - 08:25 PM
Had quick look at Mont manual. You should have a collar/spacer on the outside of each wheel bearing, and a drive on right side for the speedo cable. If these are all in place my next move would be to have a look at another 315R to "spot the difference."
#7 User is offline   swinny
  • Member
  • PipPip
  • Group: Members
  • Bike:montesa 315
Posted 06 June 2010 - 08:34 PM
ahhhhhh that must be it :rotfl: there is only one spacer on and nothing on the right hand side, so must be a spacer and drive missing. . . . might sound daft question but would i still need to put a "drive" on even though its only for offroad?? think i will have to ring sanderfords up and see if i can get the part ordered there........ cheers soo far buddy great help !!
#8 User is offline   spitfirepilot423
  • New Member
  • Pip
  • Group: Members
  • Bike:Sherco
Posted 06 June 2010 - 08:42 PM
You need the missing collar but most riders will replace the drive unit with a short machined cylinder spacer. Dealer may have a kit to replace the drive unit or any machine shop will knock one out for you. Good luck.
#9 User is offline   swinny
  • Member
  • PipPip
  • Group: Members
  • Bike:montesa 315
Posted 06 June 2010 - 08:50 PM
cheers for that buddy, will get on to it :rotfl:
#10 User is offline   patmustard
  • New Member
  • Pip
  • Group: Members
  • Bike:Montesa 315
Posted 07 June 2010 - 10:24 AM
I think the part you need is number 21 part Number 44313-NN2-900 as shown here: Apex.
Sandifords should be able to get one for you.
#11 User is offline   swinny
  • Member
  • PipPip
  • Group: Members
  • Bike:montesa 315
Posted 07 June 2010 - 08:02 PM
yeah brill for that, rang sandifords today and got one ordered, they can only ge aftermarket ones but thought it would be ok so got one on order. only about a fiver :-)
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
