Hi there, i starting riding trials bikes (gas gas txt pro 250 05 model) a couple of months ago and when i bought it i was given a measuring jug for the 2 stroke and a bottle of 2 stroke in with the deal. the guy in the shop marked out 75ml on the jug and told me that is what i should use in 5 litres of petrol. i have recently run out of 2 stroke so i bought a bottle of Motul 710 (as recomended on the gas gas shop website) and on the bottle it says i should mix it as 100ml to 5 litres, can anyone give me any advice on the right amount that i should use?
thanks
2 Stroke Recomendation
Started by jamesukm, Jun 08 2010 10:48 PM
6 replies to this topic
#1
Posted 08 June 2010 - 10:48 PM
#2
Posted 08 June 2010 - 11:08 PM
Same amount as before.... 75 ml.
#3
Posted 08 June 2010 - 11:12 PM
Hi James,
75ml or 100ml or anywhere inbetween really? It's a matter of preference. Have a look at this to help you decide - Clicky Here
If you're still unsure after that then the 'Too much is better than not enough' approach works for some folks (Usually the ones you can't see for clouds of smoke) !
GJ
P.S. I run fully synthetic at 80ml to 5 litres
GJ
He who dies with most toys wins.
It's all in the wrist action.............
#4
Posted 09 June 2010 - 08:12 AM
Modern Synthetic oils tend to need a little less in the Petrol than the older oils. I use XR77 Castrol and use 60 to 75ml in 5 litres.
Life in the Air Age isn't all the brochures Say...
#5
Posted 09 June 2010 - 10:01 AM
The gas gas pro engine runs the main bearing in gearbox oil, so the two stroke oil is only oiling the big end and small end and piston....
I've all ways use 50ml of castrol TTS to five liter of petrol and have never had any problems.
This was on a 225cc gas gas pro which liked to rev hard.
#6
Posted 09 June 2010 - 01:25 PM
cheers guys, the advice is much appreciated.
James
James
#7
Posted 09 June 2010 - 10:22 PM
Not wanting to be different ..but.. I have always run TXT 200 and KTM 300 Enduro on Putoline MX5 at 40 : 1 .. with no problems whatever. Thats why I've used it for many years.
Still need to lube 'ignition side' main bearing.
Don't notice much smoke either.
Appears to burn cleanly without deposits or gumming
