Rough Idle
  • You cannot reply to this topic
5 replies to this topic
#1 High_Fiver
    New Member
  • Members
  • Pip
  • 15 posts
  • Bike:2006 Gas Gas pro 250
Posted 15 June 2010 - 10:10 AM
Bike sounding a bit rough and spluttery when idling fine when i open the throttle
any ideas of what could be causing it ??
also seems to be running a bit hotter than normal (or maybe it's just the hot weather makes it feel like that) ^_^
all fluid levels fine using 80:1 mix and never been a problem before
thanks in advance
Ali
Edited by High_Fiver, 15 June 2010 - 10:11 AM.
#2 Lowbrow
    Advanced Member
  • Members
  • PipPipPip
  • 292 posts
  • Bike:300 Gas Gas
Posted 15 June 2010 - 11:27 AM
Cleaned the carb lately? Sounds like its due for one.
#3 High_Fiver
    New Member
  • Members
  • Pip
  • 15 posts
Posted 15 June 2010 - 11:59 AM
i'll give it a clean out
only done last month though
but worth a try
#4 chr155_d
    Member
  • Members
  • PipPip
  • 80 posts
  • Bike:sherco 2011 st 290
  • Club:Bamcc
Posted 15 June 2010 - 01:23 PM
Strip n clean carb, put in a new spark plug, clean and replace air filter! Drain replace radiator with fresh coolant! Start up using fresh premixed fuel! That should ensure it runs smoothly!
This time I'll try 2nd gear!
#5 JSE
    Advanced Member
  • Members
  • PipPipPip
  • 2,025 posts
  • Bike:Gas-Gas Pro, TY350s
  • Club:NEOTT-Life member, Texhoma Trials Club, AMA-Life Member
Posted 15 June 2010 - 01:31 PM
thanks in advance
Ali
After adjusting the mixture screw, if it's still rough I'd look into:
water in fuel or stale fuel. We often store the bikes with a partial full fuel tank which presents two problems,
a larger surface area of fuel to allow "boiling off" or evaporation of the high-end aromatics that aid starting
and low-speed running and, a volume of air that presents condensation of water. This can be cumulative and
the results build on themselves to eventually cause symptoms. I like to store my bike in between rides
with a full tank.
Possible air leak. Usually this involves the manifold/reedcage area and most often is caused by over tightening
the manifold (the capscrews only go to about 7-8 ft lbs max) which causes the manifold to bow in between the
bolt holes.
a still obstructed pilot jet. At .35/.38mm, the pilot jet is extremely small and a piece of grit can easily lodge in
it. Most of us use fuel cans for years and dirt can accumulate in the bottom of the container so it's a good idea
to add an inline fuel filter. When using compressed air to clean jets or passageways in carbs, always force the
air in the opposite direction that the air of fuel flows as the orifices are usually funnel-shaped and this will prevent
the particle from staying lodged at the bottom of the "funnel".
Jon
#6 chr155_d
    Member
  • Members
  • PipPip
  • 80 posts
  • Club:Bamcc
Posted 15 June 2010 - 03:39 PM
one more thing, check your fan is coming on? Maybe your thermostat!
