My question at the moment is how you folks have your carburetor adjusted.
I did an ultrasonic cleaning removing most all the parts but the air screw. This has a cap that prevents it from being turned fully out. Currently it seems to be running way too lean and very hot engine-wise. With the seat removed, if I place my hand over some of the air vents it will pick up speed. I assume this means it is starved for gas... but I'm not sure why. I may try and clean the carb a second time and this time remove the air screw.
I should also say this was a California bike originally. The second owner removed most of the emissions stuff and I finished the job last night. I don't think the jetting was any different from a non-California bike but I will have to check this.
Can someone tell me what the jet #'s are for a "normal" TLR200.
Also, why does this carb have two ports for the overflow gas, one on each side, and do you leave the drain tubing connected or remove it?
This post has been edited by scooterspal: 24 June 2010 - 03:53 PM
Help
