Trials Central: Electric Shock Therapy Sherco 290 - Trials Central
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Electric Shock Therapy Sherco 290 Rate Topic: -----
#1 User is offline   twinkletoes
  • Member
  • PipPip
  • Group: Members
  • Bike:beta
Posted 12 July 2010 - 09:41 AM
my mates virtually unused Sherco 290 2009 has started to give electric shocks via touching the brake lever when revving up. higher revs, bigger shock. quick check over mid trial showed no loose earth's or loose block/bullet connections. everything appears visually OK. His gloves were very wet. What next to diagnose the problem, apart from the call to MRS, obviously? Anyone else had similar problems? got him to ride slower and smoother that's for sure, but its rather a drastic way of coaching .......
#2 User is offline   axulsuv
  • Advanced Member
  • Group: Site Supporter
  • Bike: 240 pro fm330 ty80
  • Club:ITSA , STRA , MTR, AMA
Posted 12 July 2010 - 10:11 AM
Have the lights been removed from the bike ? And if so was it done correctly ? I believe sherco makes a light harness eliminator harness/jumper kit so the output of the generator gets routed correctly without regulator issues ...
Just a old trials kid !!! ITSA , STRA , MTR
And you never see a motorcycle parked in front of a psychologists office ...
"Traction is where you find it "
"To acheive anything in this game you must be prepared to dabble in the boundry of disaster" (Stirling Moss)
#3 User is offline   GrahamJayzee
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:2009 Beta Evo 290
  • Club:Cambridge Matchless MCC, Braintree DMCC
Posted 12 July 2010 - 10:31 AM
The only way you'll get a shock touching some metal is if you have a grounding issue. That may be that you have a 'floating' ground (as may happen if, as mentioned above, something like a lighting kit is removed without tieing down the output of a coil, or ensuring stray cables cannot touch metal), but may also be that a ground is dirty or loose. I'd look here first. Also look for bare insulation on any wires and particularly look around th coil area and HT lead.
Good luck, and wear wellies...
Graham
#4 User is offline   twinkletoes
  • Member
  • PipPip
  • Group: Members
  • Bike:beta
Posted 12 July 2010 - 10:36 AM
cheers guys,
to further, all the grounds were tight free from corrosion and the lighting kit is still in situ from new (its only done about 4/5 trials).
thanks
#5 User is offline   Neo
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:250 2006 (07 frame)
Posted 12 July 2010 - 11:19 AM
Just because an earth connector is held firmly in place does not mean it has a good connection.
Remove it and file flat both surfaces....Using a digital ohm (resistance) meter will also help locate the problem.
Best of balance.
Neo
This post has been edited by Neo: 12 July 2010 - 11:22 AM
My Bike ... http://www.trialscen...-2t-racing-red/
TRIALS....It's not life or death....It's much more serious than that!!
#6 User is offline   Dan Williams
  • Advanced Member
  • Bike: '05 '08 Rev3 270
  • Club:NETA, Seacoast Trials Club, East Coast Hoppers
Posted 12 July 2010 - 04:53 PM
Kill switch is bad. Not properly isolating the hot wire from the bars. Replace with a good two-wire kill switch.
The kill switch wire is usually about 400V so if the ground through the headstock is not great (it isn't) then there can be a couple hundred volts leaking onto the bars.
#7 User is offline   copemech
  • Advanced Member
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 13 July 2010 - 02:19 AM
Along the lines of what Dan stated, inspect for water entry into the bar bounted switch assy! :banana2:
Ride it Like it was one of your old Girlfriends, If you still remember how!
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
