Disc Brake On A Tlr - Sacrilege?
9 replies to this topic
#1 JMo
    Member
  • Members
  • PipPip
  • 57 posts
  • Bike:Honda TLR200
Posted 15 August 2010 - 09:55 PM
So I'm really enjoying using my TLR as a trailie-trialer, however, the front brake is still shocking [compared to a modern bike], even with new pads and an adjusted cable... I was going to try a brand new front cable just to see if it made much difference, but then I saw a 'kit' on ebay the other week caught my eye (I didn't win it as the bidding went high in the last few moments)...
Basically someone had grafted on a hydraulic caliper mount to a stock TLR left had fork leg, used a Grimeca Caliper (and presumably master cylinder), plus a Fantic front wheel with a small disc... the sell said it fitted straight on with the TLR axle.
So, is anyone familiar with this modification, or can recommend any other way of fitting a front disc brake to a TLR...? - I did consider using the complete front end off another bike - either something like a CG125 perhaps, and re-lace with a 21" rim [to keep it Honda], or even swap the whole front end for a more modern trials bike, as parts would be easier to find I imagine?
Do I have too much time on my hands and/or is this not the 'done thing' to do to old twin-shocks?
Advice and opinions please!
Jenny xx
Edited by JMo, 15 August 2010 - 09:56 PM.
"Where we're going, we don't need roads..."
JennyDakar.com
#2 Andy M
    Advanced Member
  • Site Supporter
  • 1,645 posts
  • Bike:Various..;- )
  • Club:Ledbury MCC. (Herefordshire).
Posted 15 August 2010 - 10:31 PM
If you are riding trials then it is sometimes frowned upon. Try the new front cable but buy genuine Honda and make sure the shoes are good and centralise the front wheel when fitting it. It will never be as good as a modern disc but with a bit of fettling can be better than some drums...... :rolleyes:
Edited by bo drinker, 15 August 2010 - 10:32 PM.
"Be on good terms with all persons. Speak your truth quietly and clearly, and listen to others; even the dull and ignorant. They, too, have their story."
#3 Old trials fanatic
    Advanced Member
  • Members
  • PipPipPip
  • 2,061 posts
  • Bike:James Bulto TY Ossa
  • Club:Peak Classic, Dales Classic, AA, Tufty.
Posted 16 August 2010 - 08:37 AM
Disc brakes on twinshocks Grrrrrrrrrrrrrrrrr :rolleyes:
The Victor Meldrew of Trials Central. Dont believe everything you read about me because the truth is much much worse !! LOL
#4 max1956bikes
    Advanced Member
  • Members
  • PipPipPip
  • 256 posts
  • Bike:hondas
  • Club:nene valley
Posted 16 August 2010 - 04:53 PM
i reckon very good idea.many years ago i put disc on my tl125.but if you keep drum brake clean brake out every time you use bike sand paper on shoes as they go hard and glaze up. when tightening front axle keep front brake on this centrals the shoes.
#5 JMo
    Member
  • Members
  • PipPip
  • 57 posts
  • Bike:Honda TLR200
Posted 16 August 2010 - 06:37 PM
Thanks guys - it all sounds like good advice (I did think that some purists would get a bit twitchy at the suggestion - although would/does it actually exclude you from certain classes or not?)
I'll certainly try a new cable and holding the front brake on when I tighten the front axle to see if that makes much difference - out of interest, I know people tend to recommend the OE cable (that is what is fitted to my bike at the moment) but are Venhill a good alternative?
Many thanks!
Jenny x
JennyDakar.com
#6 scooterspal
    Member
  • Members
  • PipPip
  • 66 posts
  • Bike:Hnda TLR200
Posted 17 August 2010 - 09:36 PM
I just purchased some new shoes made by EBC brakes. They have these deep grooves cut into them at a diagonal.
Have not installed them as yet. The grooves should, as I understand it, help to dissapate the heat but perhaps they will also allow the brake powder to be cleaned off the drum and moved to the inside. Therefore, allowing the remaining brake material to continue to grab better.
Any thoughts?
Edited by scooterspal, 17 August 2010 - 09:37 PM.
#7 paulmac
    Advanced Member
  • Members
  • PipPipPip
  • 156 posts
  • Bike:GasGas Bultaco
  • Club:Trials Club of Canberra - Wollongong MCC
Posted 19 August 2010 - 07:30 AM
Any thoughts?
The diagonal cuts were basically to try and get rid of water...
L'escargo...
#8 scooterspal
    Member
  • Members
  • PipPip
  • 66 posts
  • Bike:Hnda TLR200
Posted 19 August 2010 - 01:46 PM
This is true and here is the complete description from their site
"WATER GROOVED EBC aluminium series brake shoes are made using high pressure Die cast alluminium platforms with bonded brake linings. All shoes are radius ground and edge trimmed and also feature lead in and lead out chamfers at lining ends and original equipment style brake shoe springs.
The multiple angled liner grooves are designed to channel away dirt, dust, water and debris from the braking area to improve braking and extend shoe and drum life."
Has anyone tried them and are they effective?
Edited by scooterspal, 19 August 2010 - 01:48 PM.
#9 hondanut
    Member
  • Members
  • PipPip
  • 55 posts
  • Bike:tlr200, + others
Posted 19 August 2010 - 03:08 PM
i have used all different makes of shoe on my tlr, as well as cable, cams, even a differnet wheel and its still rubbish, so i now hardly ever use the brakes, my xl 185 however has quite good brakes for a twinshock
i do sometimes compete against a chap, (in the s-west) who has a disc conversion on a tlr, but aparently it was an early 80's conversion available.
#10 mcman56
    Advanced Member
  • Site Supporter
  • 405 posts
  • Bike:Rev3, Reflex
  • Club:PITS
Posted 22 August 2010 - 02:37 PM
Taking some of the flex out of the control helps. A slightly shorter brake cable, such as a 1990 XR100, cable is good...at least on the Reflex. A big rigid lever and perch such as stock Honda is also good. On the Reflex, the front brake is larger than the back and works pretty well when properly assembled but uses a fairly small axle. Have you looked at XR200 front wheels?
