shutting engine off in emergency
#1
Posted 30 September 2010 - 08:56 AM
Apologies if this has been dealt with before but I'm new to trials. My 10 year old son and 14yr old nephew are riding beta's in junior divisions at the moment. We've had a few instances of bikes getting stuck on full revs ( for a number of reasons, (dropping,caught cables etc.)On a few occasions the engine kill button doesn't work ( I presume because the engine is so hot at that stage. Can anybody tell me what is the best method of stopping the engine when this happens ?
Some suggestions we've heard are "turn the bike upside down", "Rip the carb off asap" or "block the exhaust with your hand and choke the engine"
Any help would be appreciated,
Thanks
#2
Posted 30 September 2010 - 09:32 AM
#3
Posted 30 September 2010 - 09:49 AM
I think pulling the fuel line off will create more serious problems, i.e. possible fireball consequences!
#4
Posted 30 September 2010 - 09:57 AM
And do not pull the Fuel line off, you'll probably be ingulfed by a nice big Ball of flames.
Kill switches don't really work at full revs, because the bike creates it's own spark to run off, and the switch dosen't cancel it out.
( Thats a basic description )
Best way is stick your hand over the exhaust and choke the engine.
Or if it's in gear and revving, tap the back brake to stall it.
but choking is favoured method!.
Edited by hrc_monty, 30 September 2010 - 09:59 AM.
#5
Posted 30 September 2010 - 10:54 AM
#6
Posted 30 September 2010 - 10:55 AM
Where's your sense of adventure?
#7
Posted 30 September 2010 - 11:35 AM
#8
Posted 30 September 2010 - 11:36 AM
Turn fuel tap off and put choke on - takes a while to work
If it is in gear and you can get to the rear brake pedal, try stopping it with brake. Top gear works best if you can shift the gears.
If you can flip it completely upside down without getting tangled in the chain or rear wheel, it will stop immediately with no further effort
If you can do it without burning yourself, block the exhaust outlet. A bunched up cloth/shirt usually works well for this.
So far I have stopped three runaway motors (Beta, Beta, Beta) by inverting the bike, another by using the rear brake (TY250Z) and another by blocking the exhaust outlet (Beta). A friend of mine suffered a piston/bore seizure using the turn-the-fuel-off-and-walk-to-a-safe-distance technique.
Removing the plug cap will not stop a motor if the kill switch wont and is incredibly dangerous regarding risk of stopping your heart and breaking your arm
Taking carby off will be effectively giving bike full throttle for brief period before it stops
#9
Posted 30 September 2010 - 11:38 AM
She just shrugged and told us that was what her Dad had showed her to do!
#10
Posted 30 September 2010 - 12:10 PM
Select top gear..
Back brake on..
Clutch out..
Motor should stall nicely.
I've seen the 'muffle-the-muffler' not work at all?
There are two types of men in this world:-
1) Those who are Geordies and..
2) Those that want to be.
#11
Posted 30 September 2010 - 03:28 PM
#13
Posted 30 September 2010 - 08:12 PM
#14
Posted 30 September 2010 - 09:34 PM
#15
Posted 30 September 2010 - 09:50 PM
I've not had great results trying to choke the exhaust, apart from a burnt hand. Pulling the plug cap doesn't usually work either as the bike is basically running like a diesel by compression ignition. If you can't get it upside down then trying to stall it is probably your best bet.
Oddly, never had or seen it happen on a 4 stroke, maybe not got a high enough comp ratio.
