gasser 125 oil
6 replies to this topic
#1 andytheplumber
    New Member
  • Members
  • Pip
  • 8 posts
  • Bike:working on that
Posted 15 October 2010 - 07:47 PM
HELP,I have got a hold of a 06 125 pro racing,got it from ireland(a top trials expert)...anyway I drained the engine oil and its exactly like chocolate milkshake but smells like oil.what will I do...I think I will put new oil in and leave it on test..
#2 steve1979
    Advanced Member
  • Members
  • PipPipPip
  • 195 posts
  • Bike:GG 03 txt pro 250
Posted 15 October 2010 - 08:07 PM
While the oil is drained, take the water pump off by unscrewing the three alan screw's ( you don't need to drain the system) and check the water pump seal if there's signs of antifreeze leaking out it needs a new seal. If it does there's a vid on you tube showing how to do this. Also if it needs a seal check the condition of the turbine shaft.
May not be the cause but worth a check to rule it out :thumbup:
The Shetland Stig
#3 TheDodge
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:Gas Gas TxT edit 02
  • Club:Frodsham & District MCC
Posted 15 October 2010 - 10:45 PM
The milkshake is emulsified oil and water. they will not mix at a chemical level so the froth is what you are left with. There is likely to be a pump issue as already mentioned or possibly a leak from the water jacket gaskets on the barrel. Pump seems to be most likely at this stage from collective experience. If you strip the top end have a gasket set ready.
#4 andytheplumber
    New Member
  • Members
  • Pip
  • 8 posts
Posted 16 October 2010 - 07:26 AM
#5 andytheplumber
    New Member
  • Members
  • Pip
  • 8 posts
Posted 16 October 2010 - 07:28 AM
ok thanks, I will have a look but it looks like there has been some movement there because the pump cover is very new looking,
#6 Sting32
    Advanced Member
  • Members
  • PipPipPip
  • 311 posts
  • Bike:08 GG Raga 300 Pro
  • Club:AVTA (Wichita KS)
Posted 19 October 2010 - 05:36 PM
Very possible that if someone replaced the seal, to have put it in backwards. Devil's in the details.
Kansas, Sr Expert.
#7 JSE
    Advanced Member
  • Members
  • PipPipPip
  • 2,025 posts
  • Bike:Gas-Gas Pro, TY350s
  • Club:NEOTT-Life member, Texhoma Trials Club, AMA-Life Member
Posted 19 October 2010 - 06:06 PM
Generally the frothing will be only related to the W/P seal failure.
The base gasket on the cylinder does not have a water passage
(only in an old 90's JT 250 model that had a water jacket in the cases).
A cylinder head inner o-ring failure will allow exhaust gases into
the coolant system and result in coolant loss out the radiator cap,
mimicing overheating but can happen when the coolant is not at boiling
temperature.
An outer o-ring failure head will allow seepage at the head/cylinder junction.
Jon
