ty175 advice needed
#1
Posted 07 November 2010 - 09:54 PM
Just purchased a bike for rebuild and wondering if anyone can advise the following:
1. What psi should i get when the bike is kicked over? Im getting a max of around 75 psi on the gauge?
2. Kick start sometimes engages sometimes not any suggestions?
3. Also got no spark from the coil, ammeter giving 12000 secondary and about 1 -2 ohms primary? (Book says 6000 and 5-6 repectively?)
4. Have checked the wire to the coil and ammeter showing 1.5 ohms as per book, but when kicked over doesnt seem to emitting any charge? any ideas what this should be?
Appreciate any advice please.
pete
#2
Posted 07 November 2010 - 11:15 PM
Pressure depends on how much oil is present. Ring wear/condition should be judged using end gap and appearance of piston and cylinder walls
Taks clutch cover off and have a look at the mechanism
Your resistances may be a bit different to the book if your coil is not the standard coil.
Can't understand your question. If you want a rough test to see if the magneto is working, disconnect the HT coil from the magneto, set the multimeter to volts and measure what voltage you get between the wire to the HT coil and bike earth as you kick it over. There should be a brief voltage pulse each time the points open if the magneto is working.
pete
#3
Posted 08 November 2010 - 07:25 PM
Cheers,
Stork
#4
Posted 08 November 2010 - 08:03 PM
Will investigate further and let you know what happens.
Pete
#5
Posted 08 November 2010 - 08:16 PM
pete
#7
Posted 06 January 2011 - 07:24 PM
Cant decide on frame colour SILVER or WHITE???????
Will post some pictures as soon as poss
#8
Posted 06 January 2011 - 09:03 PM
#10
Posted 14 January 2012 - 02:29 AM
GALLUNK, on 11 January 2011 - 11:14 PM, said:
Thanks
what colour did you go for? I did mine in silver, and painted, rather than powder coat. http://motorcycleres...toration-i.html
http://4.bp.blogspot...M/s1600/080.JPG
Regards Simon
http://motorcycleres...s.blogspot.com/
#11
Posted 14 January 2012 - 06:23 PM
#12
Posted 16 January 2012 - 10:48 PM
Regards Simon
#13
Posted 16 January 2012 - 11:28 PM
Hope you like my photos. Still a ways to go to complete the bike but all the hard work done!
http://s1063.photobu...nt=IMAG0140.jpg
http://s1063.photobu...nt=IMAG0165.jpg
#14
Posted 17 January 2012 - 10:13 AM
What other equipment is required?
#15
Posted 17 January 2012 - 07:29 PM
I first built a blasting cabinet, again big enough for larger parts. Also bought a bigger compressor and a blasting pot off of flea bay! Was just going to do the small bits using a household oven then decided to build my own. Commercial curing ovens are a tad expensive so I built one to my own spec.
The powder coating gun was relatively cheap and you dont need anything complex to make a booth for the powder coat as its sprayed at low pressure.
The basics required are an oven, powder coating gun/system, powder coating powder, Hanging enclosure to spray the parts and a compressor. You don't need a large compressor for powder coating, but you do need a method of stripping your parts either by sandblasting or chemical stripping.
Hope this helps
Alternatively if you want any bits doing let me know.
Cheers
